Hi, @leeon in Chinese Forum reported a FC Windows 10 problem https://forum.freecadweb.org/viewtopic.php?f=40&t=36923
Running the windows version below return error below, I have no Windows to test, see if anyone can help?
FC - - - FreeCAD_0.19.16886_x64_LP_12.1.2_PY3QT5-WinVS2015
Windows - - - Microsoft Windows 10 Pro 10.0.17763.503 (Win10 RS5 [1809] October 2018 Update)
[Solved] FC 0.19_pre - Access Violation on Win 10
Reason: Added [Solved] to title
Re: FC 0.19_pre - Access Violation on Win 10
It may be helpful for the experts
- to see the full FreeCAD infos
- to know where FreeCAD is installed. Does the path contain any chinese characters?
- Does the user name contain any chinese characters?
This error happens at the start-up phase of FreeCAD. So, no easy way to determine full version information.- to see the full FreeCAD infos
(Theoretically) with Python3 all the issues with non-ASCII characters in path or user names should be solved now.- to know where FreeCAD is installed. Does the path contain any chinese characters?
What I found strange is that after the message Python is searching for its files in the following directories: no directory is listed.
Thanks for looking into this problem.wmayer wrote: ↑Sun Jun 16, 2019 8:47 amThis error happens at the start-up phase of FreeCAD. So, no easy way to determine full version information.- to see the full FreeCAD infos
@leeoon indicates he 'has installed latest version of Python3' (已经装了Python3最新版了) - I do not know what does it mean exactly as I do not use windows for a long while. Any help or any idea what information from @leeon can help?
Next thing he should try is to start FreeCAD from a terminal windows with the option --write-log. This should create the file FreeCAD.log under %APPDATA%\FreeCAD. It would be good to get the content of this file.
Thanks @wmayerwmayer wrote: Next thing he should try is to start FreeCAD from a terminal windows with the option --write-log. This should create the file FreeCAD.log under %APPDATA%\FreeCAD. It would be good to get the content of this file.
Ping @leeon
(Chinese Translation:-
[English speaker please bear a moment ]
在 終端機 (視窗 的是 Command Prompt ?) 執行Freecad (大小楷不明) 加上 --write-log
在
%APPDATA%\FreeCAD
取得
FreeCAD.log
回覆 討論區 貼上 )
@leeon indicates he copy FreeCAD to the 'root' directory (c: ?) and it becomes fine.
He guess it may be some directories contain Chinese characters.
Trying to ask him for me details if he can provided.
This git commit 4e4631707 fixes the problem.
