Fill a hollow solid
Fill a hollow solid
I've got a GL32 screw cap which is open on both ends. I need to fill the space in between so I can use the new solid in a Boolean operation (cutting another solid with this filled screw cap). Is there way to do this in FreeCAD?
OS: macOS 10.14
Version: 0.18.16117 (Git)
Branch: (HEAD detached at 0.18.2)
Hash: dbb4cc6415bac848a294f03b80f65e888d531742
Python version: 3.6.7
Qt version: 5.6.2
OS: macOS 10.14
Qt version: 5.6.2
Re: Fill a hollow solid
There are many ways. But basically depend on where your object comes from. STEP file, mesh, Part or PartDesign, ...
Could you please attach the model as it is currently ?
Hi openBrain,
of course: GL fill.FCStd
I performed a checkGeometry with BOPCheck enabled and I'm afraid you will not get very far with this: It took very long at 100% CPU and finally came up with lots of errors (BOPAlgo_GeomAbs_C0, and BOPAlgo_InvalidCurveOnSurface).
OK, as the G32 shape looks like a "skin" (an open shell actually), here is what I did to get a solid.
- Using Defeaturing Workbench, create the 2 missing faces by selecting the appropriate edges
- Select the original shape + the 2 created faces and use Draft Upgrade to get a shell
- Use Draft Upgrade a second time on the shell to get a solid
Also see the check was highly loading the CPU, and finally canceled it. However I checked the above method making a boolean cut in the obtained solid, end everything seems OK.
I was successful as well by using the shell to slice a cylinder of appropriate size Radius=20, Height=17,9.
I cannot upload it here, because the file grows to 1.7 MB.
- Bildschirmfoto 2019-06-19 um 23.10.34.png (51.43 KiB) Viewed 4375 times
File light enough to be forum compatible. Find attached.
- GL32_fill_OB.FCStd
- (968 KiB) Downloaded 73 times
If I make a simple copy from the slice the filesize drops to 88KB too. Here the price for keeping it parametric is approximately doubling the size.
One issue you might run into when you make an internal thread by cutting a solid using the external thread as a cutting tool is you won't have any tolerance. They'll both be the same size, making for a really tight fit, perhaps too tight. Consider scaling the cutting tool to some slightly larger size, but only in x and y directions.
Thanks all, that did the job very well!
(Had to create a simple copy in order to use it in a Boolean operation, though)
