I want to do exactly the same but I dont find the Workbench anymore, is not combatible with my version.
Are there another ways to do that?
OS: Windows 10 Version 2004
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Fill a hollow solid
Re: Fill a hollow solid
The only workbench mentioned in this topic is Defeaturing. It is still available and it works with your version of FC.
What did you try to do, and what was the failure message?
Gene
i found the Add-on. Than you so much.
And it worked for another Part that I wanted to Fill. This part was easy.
But I am trying now to fill the big inner diameter of this one.
The function "Clean Faces removin holes and merging outwire" and "add Faces from in List Edges" does not do what I expected. This function curiously translate the other elements. What am I doing wrong?
- videoFreeCAD6.zip
- (706.44 KiB) Downloaded 12 times
- 087.0494.04_ASS_Koaxaial_stp.step
- (226.08 KiB) Downloaded 12 times
Instead of defeaturing you may consider to create a cylinder filling the hole.
