Need help with Boolean Cut
Hello,
If anyone could help me that would be awesome.
I can't do the cut I want
I have those two parts :
and I'd like to keep the bottom of the 1st part, by "cutting" the 2nd one from it.
The problem is that it doesn't work.
I tried selecting the 1st part first, then the 2nd. Or the opposite.
Best I could do was to do the opposite of what I want = removing the 1st part from the 2nd...
The other outcome result in an empty document (both parts gone).
Am I doing anything wrong ? (I guess I am )
Thanks,
Version: 0.18.16117 (Git)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Locale: French/France (fr_FR)
Thanks,
Qt version: 5.6.2
- papyblaise
Re: Need help with Boolean Cut
Hello
location = France , may be you speack french not sure
could you transfert your question on the french forum , and explain clairly what do you went
It seems from the images that you are dealing with a mesh. Cut works on solids.
I think it was imported as a mesh, then converted to a solid. Probably the mesh had issues.
Looks like you two are right, first thing I would check is when the mesh was converted to a shape was it converted to a solid or just a shell? Also often you get self-intersecting issues or the mesh was not a "water tight" mesh (had gaps, missing faces).TheMarkster wrote: ↑Sat Jun 22, 2019 5:44 amI think it was imported as a mesh, then converted to a solid. Probably the mesh had issues.
Try Part WB "Check Geometry" in the Pat menu, look for errors in the output and expand the "Shape Content" window to see what it says.
Jim
here it is !
https://we.tl/t-tjC01UexwS
(couldn't attach it with the forum thing, too big)
edit : ok so for some reason it worked today ...
I actually redid the file because the one I made in the OP about was on my work laptop, and this is on my home PC...
anyway, sorry for the trouble
Actually I spoke too soon, I have the same issue here :
I can't simply remove the grey part from the purple part.
the result looks like this :
I don't understand why it's so complicated
the file is here : https://we.tl/t-k4mVtPRov1
thanks for your insight
I would have a look if you can upload it to a fileservice where no accepting of any conditions beyond accepting cookies is involved.
Did you perform the geometry checks mentioned above?
this is what I get :
so I guess something's wrong.
I attached the file here by splitting it, remove the ".RENAME-ME.TXT" at the end of the files. It's a splitted zip file
- 30deg_ImpulseRC_Reverb_GoPro_session_mount_v2.zip.003.RENAME-ME.TXT
- (116.68 KiB) Downloaded 24 times
- 30deg_ImpulseRC_Reverb_GoPro_session_mount_v2.zip.002.RENAME-ME.TXT
- (1 MiB) Downloaded 24 times
- 30deg_ImpulseRC_Reverb_GoPro_session_mount_v2.zip.001.RENAME-ME.TXT
- (1 MiB) Downloaded 22 times
