A difficult subtraction in Part Design
Re: A difficult subtraction in Part Design
Here are both fanducts. Not mine design, just downloaded from Thingiverse
Notice the nail polish covered ends of the old one. It worked like that quite some time. Fillament seemed expensive at the begining
Yes, we are... but we are sorry
Thanks a lot! I have already guessed it I was printing a new duct when I read your message
Yes. This way the exit will point up and if the angle is more than 40-45 deg it should print ok without any supports. I made an single body (no treasure there )model of your duct:
I had something like this... but all holes were already closed at the 6th layer (height is 0.2 mm, bottom/top are 1 mm).Notice that at the first bridge layer it might fail because the slicer tries to connect bridge to bridge:
Ok, thanks.So before printing allways check your generated g-code and if you think that it might fail somewhere think what to modify in the model/slicer settings/supports included in model,... to fix it before printing.
It is russian, but there are many photos and Cura English screens.
https://3deshnik.ru/forum/viewtopic.php ... 435#p42085
https://3deshnik.ru/forum/viewtopic.php ... 360#p42077
I have some error messages:
What is this?No extension found of type 'PartGui::ViewProviderAttachExtension'
When I open your file.
Those errors are in Report View.
Are those errors (red) or warnings (yellow)? Nothing shows here with:
OS: Windows 8.1
Version: 0.19.17271 (Git)
Hash: 2d8f7ef2b47a335f99036bf328f51da1e6d015d9
Python version: 3.6.6
Qt version: 5.6.2
Locale: Bulgarian/Bulgaria (bg_BG)
Are you sure those are from that file? RMB on report view/Clear to remove all messages. Open the file. Do you stil get them? Nothing fancy in those moddels to show such errors.
OS: Windows 8.1
Qt version: 5.6.2
koluna, what is your FreeCAD info?
OS: Linux Mint 18.1 Serena
Version: 0.18.16093 (Git)
Branch: releases/FreeCAD-0-18
Hash: 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce
Python version: 2.7.12
I am sorry. I have forgotten to show it.
It is red. It is in your file.
- err-0.png (99.82 KiB) Viewed 950 times
Can you retry with a current 0.19? I think there has been some work concerning these extensions.
