ARCH Rebar - what is cause of unintialized variable
elsordo
Postby elsordo » Thu Jun 27, 2019 2:07 pm
I am getting a stack dump in the report view. The dump is caused by a reference to an uninitialized variable in the Rebar Tool.
Unknown command 'Draft_Edit'
File "/home/dglaser/.FreeCAD/Mod/Reinforcement/StraightRebar.py", line 137, in clicked
self.accept(button)
File "/home/dglaser/.FreeCAD/Mod/Reinforcement/StraightRebar.py", line 157, in accept
rebar = makeStraightRebar(f_cover, (coverAlong, cover), rt_cover, lb_cover, diameter, True, amount, orientation, self.SelectedObj, self.FaceName)
File "/home/dglaser/.FreeCAD/Mod/Reinforcement/StraightRebar.py", line 211, in makeStraightRebar
FacePRM = getParametersOfFace(structure, facename)
File "/home/dglaser/.FreeCAD/Mod/Reinforcement/Rebarfunc.py", line 220, in getParametersOfFace
return [(facelength, facewidth), (x, y)]
<class 'UnboundLocalError'>: local variable 'facelength' referenced before assignment
My version of FreeCAD is
OS: Ubuntu 18.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.17140 (Git) AppImage
Hash: 961ffce93e0fff6f1bf8326af248fda3f608215f
Python version: 3.7.3
Qt version: 5.9.7
The model that is causing the problem can be accessed via the following dropbox link.
https://www.dropbox.com/s/547qmfyoua9mp ... FCStd?dl=0
The screenshot that illustrates the error can be accessed via the following dropbox link
https://www.dropbox.com/s/t50x72vikxubn ... 5.png?dl=0
papyblaise
Re: ARCH Rebar - what is cause of unintialized variable
Postby papyblaise » Thu Jun 27, 2019 2:16 pm
Hello
Screnshot, Fc file , Questions : don't correspond :?:
elsordo
Postby elsordo » Thu Jun 27, 2019 2:52 pm
PappyBlaise, I renamed the model when I saved a copy to my dropbox account. I will rename it and correct the dropbox link.
With regard to the screen shot and the questions, I would like some clarification. The screenshot is indeed the coreect one and I don't understand your comment about the questions.
-David
papyblaise
Postby papyblaise » Thu Jun 27, 2019 3:35 pm
Don't panic, it's my fault , I open the wrong one , sorry
elsordo
Postby elsordo » Fri Jun 28, 2019 6:13 pm
Some more info.
I created a stand alone column that was not connected to the structure and created a straight rebar with no problem. I used the defaults in the dialog box.
This tells me that something is wrong with the ARCH Structure object that causes the rebar tool to barf. What should I look for?
Would a face from a different object intruding into the solid representation of the ARCH Structure cause the problem?
-David
