[SOLVED] Display bug in latest 0.18 release version
Gorgo13
Postby Gorgo13 » Sat Jun 29, 2019 9:31 am
Hello, please find below the report of a display bug that I had on all release versions of FreeCAD 0.18.
This bug is not present in FreeCAD_0.18.15998_x64_dev_win (this version has not crashed at all since I installed it, and with rather highly complex parts and assemblies).
Regards. G13
FreeCAD information:
Version: 0.18.16117 (Git)
Branch: releases/FreeCAD-0-18
Hash: dbb4cc6415bac848a294f03b80f65e888d531742
Python version: 3.6.6
Qt version: 5.6.2
Locale: French/France (fr_FR)
GRAPHICS CARD ADAPTER: AMD FirePro M4170
1. Start FreeCAD.
2. Create new project.
3. Select "Part Design" WB.
4. Create a simple object (either extrude a sketch or create a solid primitive from the "Part" WB).
5. Select the created object.
6. Modify the transparency value to a non-zero value. Notice the error message: Unhandled Base::Exception caught in GUIApplication::notify. The error message is: Access Violation
7. Try to manipulate the 3D view: the display is corrupted, updates are very slow, and the rendered object is corrupted. The 3D "gizmo hepler" (3D cube + axes) on the top-right corner has disappeared.
8. Set the transparency value back to zero: the display is now back to "realtime", but the display is still corrupted, i.e. mostly completely white faces, and manipulator gizmo helper reappears but is not correctly rendered.
See attached pictured illustrations.
Transparency set to 1. Display corrupted, 3D axis disappeared.
Moving the view gets things even worse.
Transparency back to zero. Display functionnal, but corrupted render (as well as the 3D axes).
papyblaise
Re: Display bug in latest 0.18 release version
Postby papyblaise » Sat Jun 29, 2019 9:59 am
salut
and if you do "Zoom all , did the bug perciste :?:
alberich
Postby alberich » Sat Jun 29, 2019 10:31 am
I do not find this behavior with
OS: Linux Mint 19.1
Version: 0.18.16117 (Git) AppImage
Branch: (HEAD detached at 0.18.2)
Python version: 3.6.7
Qt version: 5.6.2
Intel graphics card
Gorgo13
Postby Gorgo13 » Sat Jun 29, 2019 9:27 pm
Hello papyblaise
salut
Yes it persists (tu parles bien du bouton "afficher l'ensemble du contenu à l'écran"?)
It must probably be a graphics driver problem, but oddly this does not happen on some dev versions (the one I've metionned at the beginning of my post).
G. Treize
Exekute
Postby Exekute » Sat Jun 29, 2019 10:39 pm
I'm having the same issue.
RX580 graphics card using the latest driver (19.6.3)
TheMarkster
Postby TheMarkster » Sun Jun 30, 2019 12:21 am
Download the latest 0.19 release on the releases page. It works for me. Also the python2 / qt4 version of 0.18 works.
My FreeCAD video series on youtube: https://www.youtube.com/c/mwganson
openBrain
Postby openBrain » Sun Jun 30, 2019 11:51 am
Salut G13, welcome on the forum,
Could you give the full FC info about the working release. I'd bet it's a Qt4 one. ;)
Gorgo13
Postby Gorgo13 » Mon Jul 01, 2019 7:46 am
Hello all,
thank you for your replies.
merci.... the FC info for the working version I'm using is:
Version: 0.18.15998 (Git)
Hash: 5791c341be797ff2eee99eccac53df71db510fae
Python version: 2.7.14
OCC version: 7.2.0
quite different versions for Python, Qt and OCC... how can I fix this then?
openBrain
Postby openBrain » Mon Jul 01, 2019 9:12 am
You could live some time with Qt4 build but this isn't a sustainable solution.
From another topic, it seems that Qt5. 12.1 solves some issues. Could you try this dev release to confirm?
Gorgo13
Postby Gorgo13 » Mon Jul 01, 2019 7:45 pm
openBrain, yes it's working!
So what should I expect for the next 0.19 release version?... should it still work?
