I've read the code more thoroughly and the first step, it tries to use GitPython which I would guess at least 75% of Windows users wouldn't have installed and then it uses the Wiki so I'm guessing you are running GitPython. The code section in addonmanager_workers.py I'm referring to is:
def run(self):
"""Populates the list of macros"""
self.retrieve_macros_from_git()
self.retrieve_macros_from_wiki()
[self.add_macro_signal.emit(m) for m in sorted(self.macros, key=lambda m: m.name.lower())]
if self.macros:
self.info_label_signal.emit(translate('AddonsInstaller', 'List of macros successfully retrieved.'))
self.progressbar_show.emit(False)
self.stop = True
def retrieve_macros_from_git(self):
"""Retrieve macros from FreeCAD-macros.git
Emits a signal for each macro in
https://github.com/FreeCAD/FreeCAD-macros.git
try:
import git
except ImportError:
self.info_label_signal.emit("GitPython not installed! Cannot retrieve macros from Git")
FreeCAD.Console.PrintWarning(translate('AddonsInstaller', 'GitPython not installed! Cannot retrieve macros from git')+"\n")
return
Version: 0.19.17171 (Git)
Hash: d19470a9711ea604f3ca6c93e46afadf64d5bb87
Python version: 3.6.8
Qt version: 5.12.1
