Not that time I think. No problem here with an Intel GPU.
Ticket #4041 - Lost navigation cube labels
Re: Ticket #4041 - Lost navigation cube labels
Same issue in german forum, like chrisb mentioned,
walks along with this error message in report view:
Same in your case?
XmbTextListToTextProperty result code -2
Same in your case?
On my system labels are visible but letters are squashed together.
OS: Windows 8.1
Version: 0.19.17144 (Git)
Hash: ece1b7ecbaa36d22403d6850d8498882d820db3c
Python version: 3.6.6
Qt version: 5.6.2
- nav_019.png (2.74 KiB) Viewed 1680 times
Anyone find a solution to this?
Does that change something if you change the app font?
from PySide import QtGui
Gui.getMainWindow().setFont(QtGui.QFont("Mono", 10, QtGui.QFont.Normal, False))
Thank you. Sadly, it did not help the labels in the Navigation Cube.
Any idea where the Navigation Cube takes its font from?
The Xmb error (XmbTextListToTextProperty result code -2) appears throughout the log file, but I have no idea of its significance.
SOLVED--Re: Ticket #4041 - Lost navigation cube labels
So i went looking around for a solution. I looked in the source code and saw the navigation cube used "Helvetica" font. I searched my system and I did not have Helvetica. It is proprietary but I found a free sample and downloaded it and installed the font on my system and now the labels can be seen.
This problem could be resolved by using a different font in the navigation cube.Re: Ticket #4041 - Lost navigation cube labels
'Hold your horses there fella' not sure this is Solved just yet. You found a workaround but not a solution. A solution would entail having a conditional check to see if said font in the system before setting it as the font for FC. Oh and another thing, are u saying that Helvetica (a proprietary font) is a hardcoded default in to FC??
Thank you for the correction. You are correct, it is "solved" for me. My workaround was based on finding the following in NaviCube.cpp for 0.19
and on the fact that changing the font in preferences had not effect on the navigation cube.
As I do not do coding (and my little knowledge is likely a dangerous thing), I leave it to you to say whether or not that constitutes harcoding the font into FC.
if (text) {
paint.setPen(Qt::white);
QFont sansFont(str("Helvetica"), 0.18 * texSize);
sansFont.setStretch(QFont::ExtraCondensed);
paint.setFont(sansFont);
paint.drawText(QRect(0, 0, texSize, texSize), Qt::AlignCenter,qApp->translate("Gui::NaviCube",text));
Re: SOLVED--Re: Ticket #4041 - Lost navigation cube labels
I doubt that is the problem since the text shows perfectly here for me and as far as I can tell I don't have Helvetica on this system, at least not that I can find. Wouldn't the system substitute the font with another if it can't find Helvetica?leong wrote: ↑Fri Aug 09, 2019 11:31 am So i went looking around for a solution. I looked in the source code and saw the navigation cube used "Helvetica" font. I searched my system and I did not have Helvetica. It is proprietary but I found a free sample and downloaded it and installed the font on my system and now the labels can be seen.
OS: Ubuntu 18.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.
Python version: 3.6.8
Qt version: 5.9.5
