So I've been playing around with building a box culvert that's parametric.
It's a bit of a mess, but I tried to follow what appear to be best practices for designing 3D models. If anyone is willing to take some time to look, I'd appreciate feedback on problems with my layout or better ways to have managed the geometry.
First actual parametric model
- Joel_graff
Re: First actual parametric model
Some remarks / things I would change:
Dependency graph:
- If you look at the dependency graph, you see several links going out of allowed scope.
- there are sketches and even DatumPlanes and axes outside of bodies, something has been going out of whack here, perhaps due to using several part containers. .
Sketches
- master_alignment: I always try to fully constrain sketches. Especially MasterSketches.
- headwall_sketch: instead of repeating dimensions - albeit by using expressions - I would use equality and possibly a construction line. Instead of using a 95° angle on a -5° reference line I would simply use a horizontl constraint
- master_alignment001: It seems to be nothing more than a copy of master_alignment. I would place the latter outside of all bodies and reuse it.
- other sketches seem to be identical too. You can use clones or - especially if you have to change only small parts of it - CarbonCopy.
Dependency graph:
Sketches
- papyblaise
Hello
Like Crisb saids, I have some remarqs
If you need draw a symetrical part , start your first sketch on world repers (XY , XZ or YZ ) it's more aesy to do miror or polar
You are hable to draw all parts in the same body
Whith that I redraw your project (don't respect the mesures) and you can see that the tree is better look (less mess )
- square pipe.FCStd
- (125.26 KiB) Downloaded 14 times
- square pipe.PNG (20.35 KiB) Viewed 668 times
- Joel_graff
I completely forgot about the dependency graph. Whoops. Will take a closer look.
Master sketches are kinda bothering me. They appear to be a place to throw all of your dimensions that you might re-use in multiple places elsewhere - which makes sense, as I'd rather have all of my named constraints in one place rather than dispersed throughout multiple sketches which depend upon one another. But then I wonder, why not just use a spreadsheet?chrisb wrote: ↑Mon Jul 08, 2019 4:45 am - master_alignment: I always try to fully constrain sketches. Especially MasterSketches.
As for fully constraining, I usually do that too... Not sure why I didn't here.
Ok, so the tricky part here was the culvert is mirrored along the horizontal axis. So I simply duplicated the first part and rotated it 180 degrees, rather than build the entire thing as a single part. Not sure if that's a good idea, but I don't see any easier or more effective way to mirror an object...chrisb wrote: ↑Mon Jul 08, 2019 4:45 am - master_alignment001: It seems to be nothing more than a copy of master_alignment. I would place the latter outside of all bodies and reuse it.
- Joel_graff
It wasn't clear to me how to mirror the body along an axis, which is why I broke the box culvert into two parts...papyblaise wrote: ↑Mon Jul 08, 2019 9:21 am If you need draw a symetrical part , start your first sketch on world repers (XY , XZ or YZ ) it's more aesy to do miror or polar
- papyblaise
Hare , miror isn't the right tool : your part is oriented SW , if you miror , it's becam oriented NW , the rigth tool is Polar
- Joel_graff
Right. I tried it and got the main body to work, but it seemed to make a mess of the rest of it. Probably because I don't know how to design an object to make good use of polar patternspapyblaise wrote: ↑Mon Jul 08, 2019 10:35 am Hare , miror isn't the right tool : your part is oriented SW , if you miror , it's becam oriented NW , the rigth tool is Polar
- Joel_graff
So one of the other things I've noted about 3D modeling is that it seems a bad idea to build sketches off of faces. That is, the model is more stable if a sketches built from a shapebinder, which is perhaps derived from another sketch.
In order to accommodate that, I used multiple bodies (though probably not enough) so that I could establish a shapebinder, sketch, and necessary datum plane to make it work.
@papyblaise simply built the entire model basing sketches on faces. My only concern would be changing model parameters (like the skew angle of the culvert or it's dimensions...) and having the model explode...
