FREECAD step export
grijo
FREECAD step export
Postby grijo » Thu Jul 11, 2019 10:15 am
SUP_FREECAD.zip
(659.56 KiB) Downloaded 4 times
i use FREECAD to create and edit 3D models of electronic components.
When i open a 3D step model of a component supplier (to move the component origin) and export it from FREECAD the file size increase a lot, sometimes it's up to 5 times larger.
In the attached example the FREECAD step file is three times larger.
My workaround is to open the exported step file in an 3D viewer ( i use Kistler 3DViewStation ) and save it.
Then the file size is smaller.
My question:
How can i export in FREECAD a step file with an adaquate file size. ( comparable to the original file size. )
Joachim
easyw-fc
Re: FREECAD step export
Postby easyw-fc » Thu Jul 11, 2019 11:08 am
please have a look at here:
https://forum.freecadweb.org/viewtopic. ... 08#p320208
https://forum.freecadweb.org/viewtopic. ... 85#p142700
Postby chrisb » Thu Jul 11, 2019 11:16 am
vejmarie wrote:ping
grijo
Postby grijo » Thu Jul 11, 2019 12:18 pm
I disabled parametric curves in step output.
Now the file size is nearly the same the original step file has.
Thx.
vejmarie
Postby vejmarie » Sat Jul 27, 2019 7:13 pm
sorry I was offline for a time. Good to see that you fixed your issue.
