intersection constraint in sketcher?
dimitar
Postby dimitar » Thu Jul 11, 2019 5:51 pm
Hi I am wondering if there is a way to create a constraing based on two intersecting lines in sketcher. I know it can be done with two constraints for each of the lines, but I am wondering whether it can be done with a single constraint?
saso
Re: intersection constraint in sketcher?
Postby saso » Thu Jul 11, 2019 6:37 pm
add a point?
Postby chrisb » Thu Jul 11, 2019 10:16 pm
Can you elaborate what you want?
In Sketcher many of the constraints work on infinite lines rather than on the line segments which you draw in sketcher, e.g. point-on-object: a point on the line does not have to lie between the endpoints; or tangency: the "tangent" lines don't even need to touch (which ca be seen as a contradiction to the term "tangent").
Following that concept all non parallel lines would intersect, so it would not be a very helpful solution.
dimitar
Postby dimitar » Fri Jul 12, 2019 12:17 am
this is what i mean by snapping at an intersection
But your point is well taken, and it makes sense. Thanks for explaining :)
Postby chrisb » Fri Jul 12, 2019 6:01 am
For this you have to follow saso's recommendation and and add a point with point-on-object on both lines.
openBrain
Postby openBrain » Fri Jul 12, 2019 12:25 pm
Or in the case where the line ends just at the intersection, simply constrains the line endpoint to the 2 intersecting lines with "point-on-object" constraints. ;)
DeepSOIC
Postby DeepSOIC » Fri Jul 12, 2019 1:09 pm
The two
Select the TWO edges and the point, and apply point-on-object constraint. This creates two constraints in one go. You can also constrain several points to be on one edge, similarly.
Postby chrisb » Fri Jul 12, 2019 2:28 pm
Every day there is something to be learned from here: I knew the latter, but never thought of the former.
Thanks for telling!
