There must be a drawback under some circumstances because otherwise, if it is for all cases the best solution, having this option would not be necessary.
Abdullah?
It should be the best solution in 99% of the cases, provided that your computer is not too old.uwestoehr wrote: ↑Fri Jul 12, 2019 11:19 am In the sketcher preferences there is the option "Improve solving while dragging". I want to document it but could not find out what it exactly does.
Abdullah?
Many thanks.abdullah wrote: ↑Fri Jul 12, 2019 4:51 pm With this activated, when the point moves more than, if I remember correctly, 20 times the initial mouse drag movement (yes, this is a hard-coded value), the initial solution is recalculated, which is relatively costly. This heavily reduces unwanted results, but, in old equipment or very complex sketches, and specially when both, it gives the impression that the interface is not smooth while dragging.
Is it possible for you to upload that sketch here and ping me?uwestoehr wrote: ↑Fri Jul 12, 2019 10:16 pmMany thanks.abdullah wrote: ↑Fri Jul 12, 2019 4:51 pm With this activated, when the point moves more than, if I remember correctly, 20 times the initial mouse drag movement (yes, this is a hard-coded value), the initial solution is recalculated, which is relatively costly. This heavily reduces unwanted results, but, in old equipment or very complex sketches, and specially when both, it gives the impression that the interface is not smooth while dragging.
I took now my most complex sketch but could not see any difference in speed (it takes in both cases more then a minute to solve even on my new machine). However, the option might have an effect and I documented this now accordingly: Sketcher_Preferences
Hi Abdullah, you can download it from here: http://ftp.lyx.de/Billas/150mu-09channe ... llah.FCStd
