Ticket #4124 - Sketcher angle produces errors when units set in m/kg/degree (was:Sketcher Invalid Constraint Index 22)
dimitar
Postby dimitar » Sun Jul 14, 2019 1:05 pm
Fairly new to Freecad here. I am doing a very simple sketch where, I would like to put an angle constraint. I can initally put it, but if I try to change the value, I get an " Invalid Constraint Index 22"
The reporter says the following:
Drag point: Not able to move point with the id and type: (4, 1)
My version info:
Version: 0.18.16117 (Git)
Branch: releases/FreeCAD-0-18
Hash: dbb4cc6415bac848a294f03b80f65e888d531742
Python version: 3.6.6
Qt version: 5.6.2
edgeAngleError.FCStd
(13.56 KiB) Downloaded 14 times
Reason: Added ticket number to thread title
GlouGlou
Re: Sketcher Invalid Constraint Index 22
Postby GlouGlou » Sun Jul 14, 2019 1:24 pm
a small sketcher bug. Set the angle to blue, then set it to 10°. It must turn up to red.
dimitar
Postby dimitar » Sun Jul 14, 2019 1:48 pm
When I change the angle constraint to blue reference mode, and double click on it to edit, I still get the same error.
kisolre
Postby kisolre » Sun Jul 14, 2019 2:00 pm
Set it to reference mode. Try to move something that will change that angle. Observe the range it could change. Something might prevent it to go up to 10 deg.
dimitar
Postby dimitar » Sun Jul 14, 2019 2:21 pm
The issue is that i cannot be as precise as I need to be in reference mode.
papyblaise
Postby papyblaise » Sun Jul 14, 2019 2:25 pm
hello
I don't know if it's a real bug but I turn around it long time to resolve 100% constraints
in this case , try to change the order of the constraints , and you resolve it
kisolre
Postby kisolre » Sun Jul 14, 2019 2:46 pm
That is not the point. First your sketch must not be overconstrained. It is not visible from the screenshot and I don't have a PC here to check. Then it must be possible to actually set that value. That is why I suggested you check the range it can change by setting it in reference mode. If it can pass from 9.9 to 10.1 there should not be reason for that warning. But if it can go just to 7 of course you will not be able to set it to 10.
bejant
Postby bejant » Sun Jul 14, 2019 4:17 pm
If I change the problem Angle Constraint from red to blue, then drag the geometry so the angle is quite close to 10 degrees, I can change the Angle Constraint back to red and then set it to exactly 10 degrees. I think that without getting the geometry close to the intended Angle first, Sketcher reaches the maximum number of iterations limit and stops before the Sketch is Solved.
20190714-NoEdgeAngleError.FCStd
(8.37 KiB) Downloaded 7 times
OS: Ubuntu 18.04.2 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.18.1.
Python version: 3.6.7
Qt version: 5.9.5
Postby chrisb » Sun Jul 14, 2019 4:35 pm
That would be my guess too. You can set the angle without the "blue deviation" by setting it subsequently to 7, 8, 9, and finally to 10.
Postby chrisb » Sun Jul 14, 2019 4:41 pm
The sketch is in the meter dimensions, while FreeCAD uses mm as its internal unit. This seems to lead to some additional imprecisions.
You can enable in the sketcher preferences the chekbox "Show advanced solver controls". If you enter sketcher you can check "Sketch size multiplier" and after that I could immediately go to the desired angle of 10°.
