No, the subject overthere is "Mysterious gap".
How to Pocket when you Fillets
Re: How to Pocket when you Fillets
I have a model, where I used the pocket to remove a part of filled. Previously it worked, I've made some changes before this and it is not working anymore, and there is an error: Pocket: Resulting shape is not a solid. Internal name: Pocket 008.
How can it be as there is the same feature and fillet at the same place, but not pocket cannot be used to remove part of it.. ?
Most likely it is because of the topological naming problem.Accessdenied wrote: ↑Fri Dec 11, 2020 4:14 pm I have a model, where I used the pocket to remove a part of filled. Previously it worked, I've made some changes before this and it is not working anymore, and there is an error: Pocket: Resulting shape is not a solid. Internal name: Pocket 008.
The edge that the pocket was attached to is no longer the same name.
Reattach the sketch to the new edge will probably fix it.
Might have to do the same for the fillet.
It would be much easier to help if we had the freecad file to look at though...
I am not sure that I want to give it to public internet.. well, here is an image:drmacro wrote: ↑Fri Dec 11, 2020 4:25 pmMost likely it is because of the topological naming problem.Accessdenied wrote: ↑Fri Dec 11, 2020 4:14 pm I have a model, where I used the pocket to remove a part of filled. Previously it worked, I've made some changes before this and it is not working anymore, and there is an error: Pocket: Resulting shape is not a solid. Internal name: Pocket 008.
Here you see my back up file, when it worked. Then I made some geometry changes, sure, I deleted and added fillet again, which goes after polar pattern 001 and which I pocked with sketch you can see in white here. I do absolutely the same, but got this error..
What I figured out is, when I raise my plane on which this sketch is seen to the height I wanted to apply this pocket and then try pocketing this fillet reverse direction, then it also do not work until it's in full height of fillet like 1,5 mm here, but if I use 1,4999, then it cuts this fillet..
I know this topology problem and I made everything new after PolarPattern001 -> new fillet (I want to cut with pocket) - > new sketch for pocket...
- papyblaise
another such a fuss. is your object "secret defense"I am not sure that I want to give it to public internet
how do you expect us to help you
oooo...hush, hush top secret aye?
As @papyblaise notes, not a whole lot more we can do but guess.
In any case, I can see at least fillet before the pocket in the body. This is at least one place where the TNP will cause you issues.
I wouldn't be surprised if there are sketches and datum planes attached to generated geometry as well.
I would suggest a thorough read through here:
Advice for creating stable models
