Hole in gear
bonny
Hole in gear
Postby bonny » Mon Jul 15, 2019 8:05 am
Hello...
I have problem how to create hole for axis in gear. The "body" seems to screw up my knowledge. (using freecad 0.18)
What is "corect" workflow to create involute gear from gear workbench and add hole (with key) (probably partdesign workbench) for axis?
In old freecad *0.16" is easy but on 0.18 I fail.
Please help.
Re: Hole in gear
Postby chrisb » Mon Jul 15, 2019 8:25 am
If you want to use PartDesign you can do the following:
- create the gear
- select it in TreeView
- create a body; this will create a BaseFeature of the gear (some kind of a clone) in the body
- add a sketch with a circle in the appropriate plane to the body
- make a hole through all, you may have to check the "Reversed" option
gearHole.FCStd
(101.08 KiB) Downloaded 11 times
bonny
Re: Hole in gear
Postby bonny » Mon Jul 15, 2019 9:43 am
Ok with this I get gear outside of body. I was thinking that should be inside body and that bother me.
bonny
Re: Hole in gear
Postby bonny » Mon Jul 15, 2019 10:01 am
Hello...
Actually doesn't work either.
I do suggested steps and got gear with hole. But the trouble is that I can't change gear itself. (number of teeth ,,,)
What I do wrong?
test.FCStd
(365.34 KiB) Downloaded 9 times
papyblaise
Re: Hole in gear
Postby papyblaise » Mon Jul 15, 2019 11:12 am
Hello
2 quick questions to Chrisb : 1st: Where comme from your profil because I can't see it when I try to open yours involutegear , so I can't modify it
2cd: How to do the helicoildal pad ? I don't know ths option
Re: Hole in gear
Postby chrisb » Mon Jul 15, 2019 1:03 pm
Bonny uses the Gear workbench. You have to install it with the Addon manager.
looo
Re: Hole in gear
Postby looo » Mon Jul 15, 2019 1:42 pm
I guess this is because of topo-naming issues. I have seen this too, but somehow this issue doesn't occure with the file posted by @chrisb. The pocket is sometimes jumping to a wrong face (see attached image)
With the 0.18 appimage from @realthunder this is also failing:
No planar Face in AttachEngine3D::calculateAttachedPlacement()!
Bildschirmfoto von 2019-07-15 15-34-47.png (36.79 KiB) Viewed 160 times
papyblaise
Re: Hole in gear
Postby papyblaise » Mon Jul 15, 2019 2:43 pm
Thanks Chrisb
bonny
Re: Hole in gear
Postby bonny » Mon Jul 15, 2019 3:26 pm
I got cut just to the half...
But few minutes was ok!
Ebicikel02.FCStd
(582.49 KiB) Downloaded 2 times
looo
Re: Hole in gear
Postby looo » Mon Jul 15, 2019 8:02 pm
Here is a short video about the behavior:
https://vimeo.com/348236617
I didn't use any part-design features here but it should show the same problem:
As the number of faces of the gear changes, also the naming of these faces changes and at one point the face which is referenced by the sketch jumps to a different position.
The reason why the sketch is not jumping at first is answered by the observation made with @realthunder's FreeCAD version:
This means after changing the number of tenths a non planar face (most likely a part of the involute) is referenced and an error is reported for LinkStage3-branch. Master simple use the previou location of the sketch.
So we have here an example of the topo-naming issue. Maybe @realthunder can give some better explanation what is going on here.
Also I am still wondering what is different in the version @chrsib made. The posted file seems to work with all different property values.
