I have attached the sketch with the hole to the main XY-plane, i.e. independent from the gear's faces. That makes such a model very robust. If I want to place it at different position I move the whole body.
That way I can make all changes to the gear locally it will keep its holes and other pads and pockets, and the position moves it around globally.
It would be even better if a gear could be created directly inside of a body. SheetMetal workbench can do this, so it seems to be possible. It is not really essential, but would make the tree even cleaner and easier to understand.
Hole in gear
Re: Hole in gear
Re: Hole in gear
My topo naming feature does not work in this particular case because the name has to come from somewhere. Usually it originated from a sketch, with every geometry inside having an auto generated unique ID. Or maybe it comes from a primitive, like a box, a cylinder, which has a fixed number of geometries. In this case, the primitive is a gear generated by a program that can change its geometry. To make use of my topo naming, the program must manually assign names to the geometry. There are APIs to do that.looo wrote: ↑Mon Jul 15, 2019 8:02 pm The reason why the sketch is not jumping at first is answered by the observation made with @realthunder's FreeCAD version:Code: Select all
No planar Face in AttachEngine3D::calculateAttachedPlacement()!
Re: Hole in gear
One of solution are to change the gear workbench too.
To have hole (and possible keyway) in the gear itself... But it's just workaround
Slavko.
Slavko.
Re: Hole in gear
Thanks for clarification!
Thanks, so in the long run the top and bottom caps need to be named.realthunder wrote: ↑Mon Jul 15, 2019 11:55 pm To make use of my topo naming, the program must manually assign names to the geometry. There are APIs to do that.
Trying to do this I see the same behavior as with the gear (A base-feature is added inside the body, but the sheet-metal objects are not inserted)
Re: Hole in gear
The Bend is inserted directly in the Body. It doesn't seem to be a BaseFeature, as I can see and set all the parameters of the bend.
- Bildschirmfoto 2019-07-17 um 01.58.36.png (13.88 KiB) Viewed 688 times
Re: Hole in gear
Ok I see, this work if I start with a part-design feature and apply sheet-metal features on top pf this. But it doesn't work if I start with a part-feature.
Anyway I don't think placing the gear directly in the body will solve the topo-naming issue. So I guess it's not yet time to change anything to the gears-wb. Better wait for the merge of @realthunder's work and afterwards rework the gear-wb to make the gears more robust.
Re: Hole in gear
You are right. Placing a gear directly in a body is a completely different topic.
Re: Hole in gear
hi, not sure if this is a good idea, but i was looking for a solution and came accross this post.
what I edned up doing, was to Involute Gear -> Draft to sketch it -> Add citcle -> Extrude back up.
