Roy_043 wrote: ↑Tue Jul 16, 2019 3:06 pm
Changing the Autoconstraint attribute on the View tab has no effect here. When opening the sketch the global preference is always used. In fact when closing the sketch the Autoconstraint attribute on the View tab is updated to match the global preference.
One has to distinguish, see
issue #4058:
Case A:
- assure you have in the sketcher preferences the option "Auto constraints" enabled
- create a new sketch
- select the sketch in the tree view
- change to the View tab and set there "Autoconstraints" to "false"
- open the sketch
result: the task dialog tells you that "Auto constraints" is on while this is not the case for the sketch.
- close the sketch
result: in the View tab "Autoconstraints" is still correctly "false"
Case B:
disabled
- change to the View tab and set there "Autoconstraints" to "true"
- open the sketch
result: the task dialog tells you that "Auto constraints" is off and this is the case, so the view tab settings was ignored
- close the sketch
result: in the View tab "Autoconstraints" is now "false"
