Fillet Issues - Links go out of allowed scope
Re: Fillet Issues - Links go out of allowed scope
Postby chrisb » Thu Jul 18, 2019 11:16 am
I still try to Part->Explode the compound, this took already half an hour and is still running. You may try in parallel, perhaps your machine/OS will handle it better. The result should be two solids - of which at least one will show the errors from above; most probably they are caused by the fillets.
openBrain
Postby openBrain » Thu Jul 18, 2019 12:04 pm
ConnorMoran wrote:
Thu Jul 18, 2019 10:04 am
I think I'll have to just overhaul the design. It's a pretty stupid limitation though. The PartDesign should have a variable radii option.
Not sure variable radii changes something. Actually the fact is that one of the face disappeared along the edge (where cylinder & square are tangent). Thus no valid radii value can match such an equation...
Postby chrisb » Thu Jul 18, 2019 12:10 pm
Killed the process; my colleages complained about the fan spinning with 100%.
kisolre
Postby kisolre » Thu Jul 18, 2019 12:40 pm
You need a new fan :) Have you forgotten "Enable STEP Compound merge"? STEP imports as wto solids here without problems. And works as body basefeature if added geometry does not touch the broken one.
CPU Fan imported.JPG (73.61 KiB) Viewed 125 times
File gets too big and no point to include it.
Here is a realisation of my idea in previous post. All in PD. I reconstrained some of the sketches.
Computer Fan_kiss.JPG (96.64 KiB) Viewed 125 times
Computer Fan_kiss.FCStd
(886.79 KiB) Downloaded 1 time
ConnorMoran
Postby ConnorMoran » Thu Jul 18, 2019 1:25 pm
Christ.
Unchecking STEP compound merge did it. It did the entire thing I was trying to do, getting the fan out of it.
Damn. Thanks! Even made both things solids.
And seeing how you did it I understand better what you meant now.
I made some changes to the design so I could fillet it. I really appreciate it thanks!
Postby chrisb » Fri Jul 19, 2019 12:13 am
You need a new fan
I could use the fan modeled here :geek: .
It is enabled. I can extract things from the compound using a compound filter
Can you explode the compound?
TheMarkster
Postby TheMarkster » Fri Jul 19, 2019 4:47 am
I wonder if that part was done with a loft.
kisolre
Postby kisolre » Fri Jul 19, 2019 6:09 am
It is enabled
It should not be. Then compound is imported as separate solids and there is no need to explode it.
Postby chrisb » Sat Jul 20, 2019 8:18 am
I succeeded filleting after introducing ever so tiny straight edges in the circle. I could not get it working with PartDesign fillet, I had to use Part fillets. If you want to look at the sketch, you have to change DisplayModeBody from Tip to Through in the view properties.
Bildschirmfoto 2019-07-20 um 10.13.19.png (34.7 KiB) Viewed 59 times
FanExample_cb.FCStd
(43.06 KiB) Downloaded 1 time
