[Bug #4061] Weird behavior in Placement dialog when using "center of mass" with Datum Plane
openBrain
Postby openBrain » Wed Jul 17, 2019 5:51 pm
Steps to reproduce :
  1. Create a blank new model and select PartDesign WB
  2. Add a new Body (activated)
  3. Add a Datum Plane and map it to XY plane
  4. Select the Datum Plane in the tree view and open its Attachment Offset dialog from the Data property panel
  5. Check the "Use center of mass" option => :shock: Notice the crazy numbers in X & Y fields of Center !!!
  6. Check the "Apply incremental changes" option => The Center fields are reset to 0
  7. Change the Angle in the Rotation group => Datum Plane disappeared from the screen
  8. Validate the task with "OK" then look at the attachment position in the property panel => :shock: Crazy numbers again !!
Notice that step 6 can be omitted with same result, but this is less weird as in this case, the Center position is itself weird.
Thanks for confirming.
OS: Ubuntu 18.04.2 LTS (KDE/plasma)
Version: 0.19. <= 2019/07/08
Python version: 3.6.8
Qt version: 5.9.5
Locale: French/France (fr_FR)
GlouGlou
Re: [Bug ?] Weird behavior in Placement dialog when using "center of mass" with Datum Plane
Postby GlouGlou » Wed Jul 17, 2019 7:20 pm
openBrain is a really hacker. :D
this things occur with 0.19 as well
Postby wmayer » Thu Jul 18, 2019 12:18 pm
Confirmed! issue #4061
openBrain
Postby openBrain » Thu Jul 18, 2019 12:29 pm
I wish I were so I can send a PR rather than opening this thread. :lol:
:o As you confirmed I was going to open a ticket and ... you were much faster. :)
