sketcher: fun with trimming
uwestoehr
Postby uwestoehr » Thu Jul 18, 2019 3:40 pm
I am aware that there are issues with trimming but all I found in the forum was reported years ago.
Nevertheless this might be a still known issue but it is a funny one:
- take this example:
trim-issue.FCStd
(11 KiB) Downloaded 13 times
-try to trim the line inside the arc to be consistent with the other arcs:
result: the line is not trimmed but extended
Is this a known issue or not?
Version: 0.19.17433 (Git)
Hash: 125380ddd9a1fdeb45ffc736040dad1f6343daa4
Python version: 3.6.6
Qt version: 5.6.2
papyblaise
Re: sketcher: fun with trimming
Postby papyblaise » Thu Jul 18, 2019 4:34 pm
Hello
it's several edge open in your sketch
for your specific question , you constraint first to the segment , you don't hable make an other constraint of length
kisolre
Postby kisolre » Thu Jul 18, 2019 5:46 pm
The problem is again some automation. When the trim is executed it automatically creates PointOnLine or Coincidence constraint (which was probably why trim was executed) depending on resulting number of edges left at that point. This is visible on a screenshot but not explained in the docs Sketcher_Trimming.
Here existing PointOnLine constraints on both arc edges make the solver to produce confusing (but valid) result. Removing bottom PointOnLine constraint makes it work as expected.
bejant
Postby bejant » Thu Jul 18, 2019 9:09 pm
I'm not completely sure but in the context of that Sketch I'm more of the opinion that this is not so much a FreeCAD issue as it is an improper method of making the Sketch, and I'm leaning that way because:
  • Auto Constraints could have been ticked to On;
  • This shape could more easily be drawn using the Polyline tool (even if creating the Sketch using several small continuous lengths of different types of geometry) instead of Sketching each edge individually and separately;
  • If the edges of the Arc(Edge7) and Line(Edge2) were originally overlapping we would normally use the Trim tool first [instead of applying the Point On Edge Constraint, and then applying a Coincident Constraint between the Endpoint of Line(Edge2) and the center of Arc(Edge7)] and so a Coincident Constraint would be applied automatically to the end of the line segment and the end of the arc (and if the edges weren't overlapping, the Point On Edge is likely the wrong Constraint to use there);
  • Geometric Constraints should have been applied before Length Constraints. Without changing any Constraints, notice how the edges can be dragged apart from one another:
To me it looks like that Sketch was purposely constructed in a manner that is opposite of how someone should make it. The ability to make good Sketches is a skill that has to be learned, and some tips are here:
https://www.freecadweb.org/wiki/Sketche ... _Practices
https://forum.freecadweb.org/viewtopic. ... 04#p248329 (at the end of the post).
FWIW the Trim tool does delete the Coincident Constraint (Constraint19) previously applied between the endpoint of the line segment and the center of the arc.
OS: Ubuntu 18.04.2 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.18.1.
Python version: 3.6.7
Qt version: 5.9.5
uwestoehr
Postby uwestoehr » Thu Jul 18, 2019 10:00 pm
Many thanks for the explanation. The question is if the solver can be improved in this respect or not. If yes, I will file a bug if not, then not.
My aim was not to get a working sketch but to find a reproducible case for a strange thing I see frequently with trimming.
(The original sketch is the result of a DXF import, thus no autoconstraints.)
In my understanding the sketcher should work as expected no matter in which order the user set what constraint or not. I mean I performed a trimming action therefore it should not matter how other sketch parts are constrained or not. I want a line to be trimmed and FC should just do this. But I get the opposite - an extension. This is at the first look very confusion and it took me few minutes to get it right.
I stumble over these workflow-breakers every day since I started to do more work with FC. More work means collaboration and and this means DXF files to import and manage. The DXF import results gives you sketches in sometimes strange state. Therefore it would be very helpful if FC would be more tolerant and just performs the actions as can be expected by the user.
bejant
Postby bejant » Fri Jul 19, 2019 1:03 am
Ok, thanks for explaining that, and we can do our best to better pinpoint the problem so that our developers can help solve it.
That explains a bit more and introduces a new variable. Personally it wouldn't bother me in the least if FreeCAD stopped supporting that closed source format, but that's a subject for a new topic.
Ok. If I create an arc and a line segment in a new Sketch and Constrain them as you did in the original file, the Trim works for me. What happens if you do the Trim in the attached file?
What happens if you recreate the Sketch from scratch yourself and do the Trim?
20190718a-trim-issue.FCStd
(9.27 KiB) Downloaded 6 times
Version: 0.18.1.
Qt version: 5.9.5
uwestoehr
Postby uwestoehr » Fri Jul 19, 2019 11:15 am
Well, you never work alone. There are many CAD programs around and the most common file format is for 2D DXF and for 3D STEP. So without a DXF importer I would not be able to construct anything else than private hobby projects with FC.
This works fine. That is why I sent the more complex geometry because the problem appears only under certain circumstances which are not yet clear to me.
Postby chrisb » Fri Jul 19, 2019 11:30 pm
I have tried to simplify the sketch and was able to reduce it just to the line and the arc. in the attached model it is the left pair.
Bildschirmfoto 2019-07-20 um 01.01.14.png (11.88 KiB) Viewed 201 times
Then things got worse.
The pair in the middle was drawn first the arc, next the line. The rightmost pair was drawn first the line next the arc. The middle pair always works as expected.
If I
- load the file
- edit Sketch
- trim the upper part of the right pair
Then another situation is shown:
Bildschirmfoto 2019-07-20 um 01.12.17.png (8.79 KiB) Viewed 201 times
If I
- undo the trimming
- remove the equality constraints
- reapply the trimming,
then the trimming sometimes works as expected.
This shows that an underconstrained sketch can show nondeterministic behaviour.
trim-issue_cb.FCStd
(4.87 KiB) Downloaded 6 times
uwestoehr
Postby uwestoehr » Fri Jul 19, 2019 11:41 pm
Many thanks. With this simple example it is easier to play with. It seems there is no simple way to avoid this effect. I played a bit and cannot find one. But that the order of the creation is important (first line or arc) is a hint that something can be improved.
I guess, this case is more load for Abdullah's upcoming rainy days sessions :)
I think we should open an issue to document this case.
bejant
Postby bejant » Sat Jul 20, 2019 1:02 am
Reported as issue #4066
