Can't scale an imported mesh
a3bksll47
Postby a3bksll47 » Fri Jul 19, 2019 8:30 pm
I try importing objects from Blender, but if I need to scale them, they will visibly scale in the FreeCAD viewport, but when I go to save the file the objects vanish.
(I made the edges and primary mass in 5 separate components to convey a pseudo-diffractive effect. None of the components save when rescaled.)
imported edges and vision glass test from blender_00.FCStd
(4.85 KiB) Downloaded 6 times
Re: Can't scale an imported mesh
Postby chrisb » Fri Jul 19, 2019 9:40 pm
It works here when I use the scale function from the Mesh Design workbench. How did you scale?
Please attach your full FreeCAD info as described in the IMPORTANT forum rules linked above.
a3bksll47
Postby a3bksll47 » Sat Jul 20, 2019 9:20 am
Version: 0.18.16117 (Git)
Branch: releases/FreeCAD-0-18
Hash: dbb4cc6415bac848a294f03b80f65e888d531742
Python version: 3.6.6
Qt version: 5.6.2
01.png is after I clicked into the central portion of the construct.
02.png is after I pressed the <Scales the selected object> button (S, C). Mouse is subsequently loosely hovered over the central portion of the construct.
03.png is after I left clicked into the central portion of the construct. I then pressed radio button <Modify original>.
04.png shows the X value is resulting in a real time change in that coordinate.
05.png is after I press <OK> sometimes. 06.png is after I press <OK> most of the time.
I don't know how to do this I guess.
a3bksll47
Postby a3bksll47 » Sat Jul 20, 2019 9:23 am
Here's 06.png, because it wouldn't upload in the prior post:
GlouGlou
Postby GlouGlou » Sat Jul 20, 2019 9:40 am
use the scale feature in mesh WB,it's working nice.
a3bksll47
Postby a3bksll47 » Sat Jul 20, 2019 10:23 am
Ok now trying to do this in Mesh Design, but none of the edits I'm trying to make in its Data tab is working for me.
Update:
Oh, it's under the menu at Meshes! Scale... and not on the toolbar. But it's only uniform, there's no X, Y, Z options.
I guess I'll have to try the Boolean operation listed.
Thanks all.
jmaustpc
Postby jmaustpc » Sat Jul 20, 2019 12:14 pm
Update:
Thanks all.
I have not tried it, but generally you should be able to convert your mesh to a solid, then you could use the non-uniform scale function, then convert the result to a mesh again.
a3bksll47
Postby a3bksll47 » Sat Jul 20, 2019 11:30 pm
I have not tried it, but generally you should be able to convert your mesh to a solid,....
I don't know how either or even if there is a way.
TheMarkster
Postby TheMarkster » Sun Jul 21, 2019 12:43 am
It looks like louvre_edges has flipped normals and other issues. You can check it in Mesh Design using Analyze tool.
If you don't know how to convert to a solid, it is done in Part workbench -> Create shape from mesh. Then once converted you can use Draft scale tool.
a3bksll47
Postby a3bksll47 » Sun Jul 21, 2019 5:42 pm
Thanks. I'll try to see what's going on in that in a few days. I hope the file size comes down as a result too.
