Create A "Clean" Sweep of this!
pekkio
Postby pekkio » Sat Jul 20, 2019 9:38 am
OS: Mac OS X
Version: 0.17.13541 (Git)
Branch: releases/FreeCAD-0-17
Python version: 2.7.14
Qt version: 5.10.1
OCC version: 7.2.0
Hi everyone,
do you think there is a chance to create a clean solid using Sweep of that profile on that track?
The result should be more or less the one of the picture attached that I obtained creating the round profile and the straight profile and doing an array. But obviously it's not a good solid and when I try to do a boolean operation on it (joining everything together) I get a mess!
B - percorso.jpg (754.13 KiB) Viewed 223 times
bacino.FCStd
(7.68 KiB) Downloaded 9 times
A - profilo.jpg (389.29 KiB) Viewed 223 times
papyblaise
Re: Create A "Clean" Sweep of this!
Postby papyblaise » Sat Jul 20, 2019 11:09 am
hello
A chance, I don't know , but with the right tools maibe Yes ,
I do 1/8 one , Miror + Array with Part Wb it's finish
With Partdesign , I can't do it
cadre.FCStd
(282.8 KiB) Downloaded 5 times
GlouGlou
Postby GlouGlou » Sat Jul 20, 2019 11:24 am
Yes, PartDesignNext can't do the polar pattern. But Part workbench is able. why? :roll:
bbb.FCStd
(102.02 KiB) Downloaded 8 times
papyblaise
Postby papyblaise » Sat Jul 20, 2019 11:54 am
why
Because this it's (parce c'est comme ça :!: )
TheMarkster
Postby TheMarkster » Sat Jul 20, 2019 9:13 pm
Another way to do this in Part workbench using Draft Facebinders. The result is fully parametric.
phpBB [video]
bacino(v2).FCStd
(62.89 KiB) Not downloaded yet
Postby chrisb » Sat Jul 20, 2019 9:36 pm
From what I see in 3D view PartDesign could do it as well. The mistake PartDesign seems to make is to erroneously assume some instances were not intersecting - which in fact they do:
Bildschirmfoto 2019-07-20 um 23.37.56.png (43.19 KiB) Viewed 161 times
pekkio
Postby pekkio » Sat Jul 20, 2019 9:41 pm
phpBB [video]
Nice solution. Never used Facebinders till now. It could solve some problem I had in other project. Do you think would it be possible to get straight corners instead of round?
pekkio
Postby pekkio » Sat Jul 20, 2019 9:43 pm
hello
Nice idea!
Postby chrisb » Sat Jul 20, 2019 10:07 pm
FreeCAD crashes if I try to do the sweep including the circle. Based on GlouGlou's model, I did the following:
- open the file
- delete Array
- hode AdditivePipe001
- double click AdditivePipe
- remove Edge3 from the path
this is the last image before crashing ...
Bildschirmfoto 2019-07-20 um 23.55.36.png (13 KiB) Viewed 148 times
... I wanted to add the preselected arc.
Can someone please confirm?
TheMarkster
Postby TheMarkster » Sat Jul 20, 2019 11:12 pm
I think so. Just replace the revolve with 2 extruded facebinders. Extrude them past each other, then take the common.
