Create A "Clean" Sweep of this!
TheMarkster
Re: Create A "Clean" Sweep of this!
Post by TheMarkster »
We can give it some extra support so that the all the pieces of the array are connected.
phpBB [video]
bejant
Post by bejant »
chrisb wrote: Sat Jul 20, 2019 10:07 pm Can someone please confirm?
I can reproduce the crash in a different manner. Open the cadre.fcstd file from the second post and edit Sketch to change the Arc from a 1/4 circle
to a 1/2 circle
FreeCAD crashes for me after closing Sketch.
OS: Ubuntu 18.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19. (build date 2019-07-08)
Python version: 3.6.8
Qt version: 5.9.5
bejant wrote: Sun Jul 21, 2019 11:46 am I can reproduce the crash in a different manner.
I can confirm that crash.
OS: macOS High Sierra (10.13)
Version: 0.19.17360 (Git)
Hash: 348160d4ea970f5f6d0850272c04800c0222c8ba
Python version: 3.7.3
Qt version: 5.9.7
bejant
Post by bejant »
I **should** be able to create the model entirely in Part Design, but using the shape contained in Sketch001 fails.
If I substitute a rectangle for the geometry in Sketch001 I can create the model in Part Design as I intended but the result fails Check Geometry when BOPCheck = True.
20190721b-PartWB-cadre.FCStd
(202.34 KiB) Downloaded 17 times
Qt version: 5.9.5
Dropping back to the 0.16 Appimage version, the Part WB > Sweep along a Sweep path of the fourth of the model in the +X, +Y quadrant works using the geometry of Sketch001. The Sweep passes passes Check Geometry when BOPCheck = True.
20190721b-016-cadre.FCStd
Created with FreeCAD 0.16
(104.1 KiB) Downloaded 12 times
Version: 0.16.6712 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
We see perhaps a regression in OCC?
bejant
Post by bejant »
I'm not sure, I have to wonder if the problem could be how FreeCAD deals with Sketcher Arcs arcs (also thinking about the Trim problem with Arcs). If I go to the Draft WB and use the Bi-Directionally Convert tool to convert the Sketches of the path and the profile of cadre.fcstd to DWires, Part WB > Sweep in the +X +Y quadrant works and passes Check Geometry with BOPCheck = True.
Edit: a Part WB > Sweep using Sketch001 as the cross-section works and passes too.
20190721-cadreDWireSweep.FCStd
(67.77 KiB) Downloaded 20 times
A Part WB > Mirror of the Sweep, then a Part WB > Fusion of the two quarters to make a half, another Mirror of the half, and finally a Fusion of the two halves also passes.
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.18.1.
Python version: 3.6.7
Qt version: 5.9.5
If I convert the wire back to a sketch the sweep works as well without errors. I will try to extract a minimal example and then Abdullah and Werner hopefully will have a look at this issue.
I have to row back.
bejant wrote: Mon Jul 22, 2019 2:03 am If I go to the Draft WB and use the Bi-Directionally Convert tool to convert the Sketches of the path and the profile of cadre.fcstd to DWires, Part WB > Sweep in the +X +Y quadrant works and passes Check Geometry with BOPCheck = True.
If I create the sweep with the original sketch from your uploaded file it passes BOPCheck as well.
kisolre
Post by kisolre »
I made an experiment with Part sweep and PartDesign sweep with the same profile and path. In the attached file both work. But when I add PointOnLine constraint between center of path arc and horizontal axis Part sweep is still Ok but PartDesign sweep fails. In my understanding they are the same operation and since the PD one is first feature in the body no extra union is performed and the result should be the same. The sould either both succeed or both fail.
PD SweepFail.JPG (62.4 KiB) Viewed 598 times
OS: Windows 8.1
Version: 0.19.17433 (Git)
Hash: 125380ddd9a1fdeb45ffc736040dad1f6343daa4
Python version: 3.6.6
Qt version: 5.6.2
Locale: Bulgarian/Bulgaria (bg_BG)
PD SweepFail.FCStd
(200.2 KiB) Downloaded 19 times
bejant
Post by bejant »
chrisb wrote: Mon Jul 22, 2019 5:46 am I have to row back.
Part WB > Sweep using Sketch001 in that file as the cross-section works here too, so I think this is now isolated to being a Part Design problem?
kisolre wrote: Mon Jul 22, 2019 6:38 am But when I add PointOnLine constraint between center of path arc and horizontal axis Part sweep is still Ok but PartDesign sweep fails.
In the file you posted, for me Additive Pipe passes Check Geometry with BOPCheck = True.
Your Sketch001 profile only has one arc while the problem Sketches have two arcs that form an S shape. When I change the profile in Sketch001 to include the other arc FreeCAD blinked out of existence after exiting Sketcher. When I reopen the FreeCAD file and edit Sketch001 a second time FreeCAD didn't crash, but Additive Pipe didn't update.
20190722b-PD SweepFail.FCStd
(219.33 KiB) Downloaded 17 times
Version: 0.19.
Qt version: 5.9.5
