[Ticket #4204] 3D parametric curve
Pauvres_honteux
Post by Pauvres_honteux »
OpenSUSE Leap 15.1
(FreeCAD Help doesn't contain any more info...)
I can not find a way to make a 3D parametric curve of arbitrary shape, ruled by two points and two direction vectors.
Note: it's supposed to be fully parametric, i.e. moving a point changes the 3D-curve shape.
Any ideas?
Datum_test_2.FCStd
(6.92 KiB) Downloaded 54 times
Last edited by Pauvres_honteux on Sat May 08, 2021 7:56 am, edited 1 time in total.
saso
Re: 3D parametric curve
Post by saso »
Blend Curve from Curves WB would give you something similar if it would support the datum lines :|
freecad-heini-1
Post by freecad-heini-1 »
saso wrote: Fri Aug 02, 2019 11:12 am Blend Curve from Curves WB would give you something similar if it would support the datum lines :|
Part-Workbench Line and Curves-Workbench Blend-Curve.
Line_and_Blend_Curve.FCStd
(5.41 KiB) Downloaded 49 times
saso
Post by saso »
freecad-heini-1 wrote: Fri Aug 02, 2019 11:30 am Part-Workbench Line and Curves-Workbench Blend-Curve.
Yes I have made something similar with draft lines, but how to map them now to datum lines or points to make this fully parametric... Note that in this example Pauvres_honteux is controlling everything from the points not the lines... :?:
Part Line (maybe also Draft Line) could probably have the same map mode options as Datum Line (Through two points) :?:
Datum_test_2 (1).FCStd
(9.71 KiB) Downloaded 37 times
saso
Post by saso »
This is better... and if you change datum points to part vertex then you are even able to use the transform gizmo on it :)
Also note, if Parameter1 and Parameter2 of the Blend Curve would have support to be overridden (driven) by an object then DatumPoint_1.1 and DatumPoint_1.2 could be used for that ;)
Datum_test_2 (2).FCStd
(8.95 KiB) Downloaded 39 times
GlouGlou
Post by GlouGlou »
Here my first video. ;)
Hope it can be helpful.
https://youtu.be/r3-ebv89MiM
BlendCurves.FCStd
(34.78 KiB) Downloaded 40 times
Pauvres_honteux
Hello Saucy Tomato! :lol:
I tried your version and it works!!! However, getting all that stuff to work in a parametric way and get it back into the Body was a bit to much to handle for my FC, it crashed...
Wouldn't it be simpler if that blend curve could accept datum's directly instead?
Anybody knows who coded that blend curve? Perhaps he can do some magic with it?
Pauvres_honteux
Chris_G wrote:
Hi Chris, I've got the impression you coded this "blend curve" thingie?
Would it be a lot of work to have it take datum-points and datum-lines as argument?
Chris_G
Post by Chris_G »
Pauvres_honteux wrote: Sat Aug 03, 2019 6:30 pm Hi Chris, I've got the impression you coded this "blend curve" thingie?
I almost never use Part Design, so I don't know these datum things much.
I had a quick look, but I don't know yet if I'll be able to add these objects as input data for BlendCurve.
GlouGlou
Post by GlouGlou »
Datumline can be draged outside a body.
Workfeature WB can do same objets as partdesign (line, point...), but is not all finished yet
