Good afternoon,
I have designed a body stored in a FreeCAD file. I also do have a different FreeCAD file (master.FCStd) in the same directory just containing a spreadsheet. This spreadsheet does hold all relevant distances. All cells carry an alias name.
Now, these aliases are not accessible from the body file. I do know how to address those expressions as I have already done that in the past (master#name_of_spreadsheet.expression).
Here comes the difference: The file with the body originally contained several bodies together with all their sketches and modeling tools. For reorganizing the project I put every body in its individual file by copying the multi part file and deleting all but one body in each file. At the same time I renamed all entries in the model tree to be "Sketch", "Pad", "Pocket" etc rather than "Sketch001", "Pad001", etc.
Now when I try to insert the external expression (no matter which from the spreadsheet) the formula editor says "Document object not found: Sketch002". There is no Sketch002 for the body, however, there was a Sketch002 in the multi body file.
Any idea of how to get rid of that for the files and if this should be considered a bug?
Best regards
Stefan
Cannot reference to expressions in external spreadsheet
- failure_external-expression.png (28.27 KiB) Viewed 2265 times
Re: Cannot reference to expressions in external spreadsheet
Can you upload the files (Master plus one of the others? And note, that renaming is rather relabeling. You can never change the internal name, only the displayed label.
Thanks for the feedback.
I realized the internal names in the status line when hovering over the items but even changing the labels back does not repair the file.
Attached two files
Attached two files
- seitenwand_lang.FCStd
- (18.94 KiB) Downloaded 90 times
- master.FCStd
- (1.59 KiB) Downloaded 73 times
The problem is the name of the spreadsheet. The dash is inside of an expression interpreted as a minus sign. Rename the spreadsheet e.g. to daten_wc_schrank and you can reference things such as master#daten_wc_schrank.hoehe_schrank in the file seitenwand_lang.FCStd.
Hey chrisb,
thanks for looking into that. That did the trick.
Best regards
Best regards
you are the masters, problem solved thanks
I will also add, that it does not work with capital letters in the filename.
FreeCAD als Maschinenbauer in die Konstruktion und Fertigung integrieren. Schulung buchen: www.alsado.de/freecad-schulungen
I recommend using links to make your documents easier to maintain. Here is an example of how that could look like:
https://forum.freecadweb.org/viewtopic. ... 60#p540257
Regards / Viele Grüße
Max
Max
