Workflow questions for 3D printing
dxp.dev
Re: Workflow questions for 3D printing
Postby dxp.dev » Fri Aug 09, 2019 5:42 pm
Bayesian wrote:
Fri Aug 09, 2019 5:26 pm
Another question: How do people manage projects with multiple parts? It seems to be easiest to have only one part per Document, otherwise it will get rather complicated to show/hide whatever it is I am working on in the moment. Is it possible to have spreadsheets that are shared among multiple documents?
You are looking for that thread https://forum.freecadweb.org/viewtopic.php?f=8&t=36529
Imperial system makes no sense, go metric ! ! !
HarryGeier
Postby HarryGeier » Mon Aug 12, 2019 5:33 am
Is anyone using one of the various Assembly Workbenches?
Not for my own stuff. As long as the discussions go on which one A2+, A3, A4 i don´t want make myself more confused as i am anyway.
I use multi body projects and link the body´s by shapebinders.
That worked for my bathroom as well as for a complex 3D Printer Hotend Carriage.
Both where ( Bathroom scaled ) for FDM Printing
Kaum macht man´s richtig , gehts´s
My Video Tutorials on Youtube: https://www.youtube.com/channel/UCoe3B ... p8Q/videos
My FreeCAD Stuff on Hidrive: https://my.hidrive.com/share/qr3l1yddy6#$/
Hannu
Location: Strängnäs, Sweden - 1hr drive west from Stockholm
Postby Hannu » Sun Aug 18, 2019 10:50 am
kisolre wrote:
Fri Aug 09, 2019 3:39 pm
Hannu wrote:
Fri Aug 09, 2019 3:05 pm
Never seen the STL file type preselected, the last used folder is remembered while FreeCAD is running;
Not sure if windows or 0.19 but here last exported file type is remembered and default folder after opening a file is its folder.
8<---
I have *never* seen it come up like that...
OS: Ubuntu 16.04.6 LTS
Version: 0.18.16093 (Git) [as posted]
That was the "daily" ppa at that time. (Hmm... was some time since that did update!? Dropped "off the hook" somewhere?)
/Hannu - engineer & mild :geek:
- Embedded, Computers, Software, Electronics, - ISO9000/14000, Claim/Audit, Deviation, Corrective action,
- Mechanics, FDM 3D-printing, Lathe, Mill, Weld -work, - A&D Photos and Prints http://flickr.com/arkane
Postby chrisb » Sun Aug 18, 2019 11:08 am
There is a parameter you can set on Ubuntu to use the system fileselection dialog - can't find it at the moment.
HarryGeier
Postby HarryGeier » Fri Aug 23, 2019 6:37 am
Here is my simple "makestl" macro
It creates a sstandardized mesh from the selected object(s) , and hides the previous 3d objects
# -*- coding: utf-8 -*-
# Create a Standard MESH on on click from the current object.
# Parameters are coded in Macro . I use them to 99.9% for 3D STL´s
# Macro Begin: makestl.FCMacro +++++++++++++++++++++++++++++++++++++++++++++++++
import FreeCAD
import Mesh
import MeshPartGui, FreeCADGui
import MeshPart
#Get the current FreeCAD Document Object
__doc__=FreeCAD.activeDocument()
Gui.activateWorkbench("MeshWorkbench")
#Get the Name of the current selected Object
sel = FreeCADGui.Selection.getSelection()
Nameelement = sel[0].Name
#Print the Name
App.Console.PrintMessage(str(Nameelement)+"\n")
#instantiate a Mesh
__mesh__=__doc__.addObject("Mesh::Feature","Mesh")
#Get the Object selected
__part__=__doc__.getObject(Nameelement)
#Copy it´s Shape
__shape__=__part__.Shape.copy(False)
__shape__.Placement=__part__.getGlobalPlacement()
#Mek the Mesh with Standard Parameters
__mesh__.Mesh=MeshPart.meshFromShape(Shape=__shape__, LinearDeflection=0.1, AngularDeflection=25, Relative=False)
#rename the new Mesh  and put into View
__mesh__.Label=Nameelement+" (Meshed)"
__mesh__.ViewObject.CreaseAngle=25.0
#Make the Feature invisible
Gui.getDocument(__doc__).getObject(Nameelement).Visibility=False
#Clean Up
del __doc__, __mesh__, __part__, __shape__
# Macro End: makestl.FCMacro +++++++++++++++++++++++++++++++++++++++++++++++++
Postby chrisb » Fri Aug 23, 2019 9:11 am
Could you please edit your post and put the code in code tags </>. It's easier to read and easier to handle.
