animation wb. outputting images to file
bzb.dev001
Postby bzb.dev001 » Mon Aug 12, 2019 3:08 pm
I'm following the instructions in http://freecadbuch.de/doku.php?id=anima ... e_schritte
I created a rotator to rotate an object using animation wb. Now I want to output the animation to a bunch of images to be converted to a video file. I've created the Photographer Dialog but have trouble configuring it to output images.
Something of note...
After using the Manager Dialog to create the My_Manager node in the model tree. Any attempt to select a function from the context menu (eg. About Manager, Edit, forward, backward, ping pong ) would result in error messages.
Selecting My_Manager context menu>About Manager...
  File "/home/wt/.FreeCAD/Mod/animation/Animation.py", line 200, in showVersion
    PySide.QtGui.QMessageBox.information(None, "About ", "Animation" + cl +" Node\nVersion " + self.vers)
AttributeError: '_ViewProviderManager' object has no attribute 'vers'
Selecting My_Manager context menu>Edit...
[['forward', <bound method _ViewProviderActor.animforward of <Animation._ViewProviderManager object at 0x7fcadf3ff518>>], ['backward', <bound method _ViewProviderActor.animbackward of <Animation._ViewProviderManager object at 0x7fcadf3ff518>>], ['ping pong', <bound method _ViewProviderActor.animpingpong of <Animation._ViewProviderManager object at 0x7fcadf3ff518>>]]
  File "/home/wt/.FreeCAD/Mod/animation/Animation.py", line 220, in edit
    self.dialog=EditWidget(self,self.emenu + anims,False)
  File "/home/wt/.FreeCAD/Mod/animation/EditWidget.py", line 68, in __init__
    _EditWidget.__init__(self, True, obj,menu,noclose,*args)
  File "/home/wt/.FreeCAD/Mod/animation/EditWidget.py", line 31, in __init__
    dial.valueChanged.connect(obj.dialer)
AttributeError: '_ViewProviderManager' object has no attribute 'dialer'
Selecting My_Manager context menu>Forward...
  File "/home/wt/.FreeCAD/Mod/animation/Animation.py", line 256, in animforward
    self.obj2.time=float(i)/100
AttributeError: '_ViewProviderManager' object has no attribute 'obj2'
Selecting My_Manager context menu>Backward...
  File "/home/wt/.FreeCAD/Mod/animation/Animation.py", line 264, in animbackward
    self.obj2.time=float(100-i)/100
Selecting My_Manager context menu>Ping pong...
  File "/home/wt/.FreeCAD/Mod/animation/Animation.py", line 270, in animpingpong
    self.animforward()
Same issue with all the animation wb objects added to the model tree.
FreeCAD details
OS: Ubuntu 18.04.3 LTS (LXDE/Lubuntu)
Version: 0.19.17512 (Git) AppImage
Hash: 7b315d3a15f6c0a3e796b2bf000cb791092de079
Python version: 3.7.3
Qt version: 5.9.7
Any help greatly appreciated.
sample-animation 1obj.FCStd
(4.85 KiB) Downloaded 11 times
bzb.dev001
animation wb: cannot create placer
Postby bzb.dev001 » Mon Aug 12, 2019 3:30 pm
I created a solid and then switched into Animation wb to create a Placer. When doing so results in an error message.
Animation workbench deactivated
Animation workbench activated
Running the Python command 'Anim_Placer' failed:
  File "<string>", line 74, in Activated
name 'reload' is not defined
FreeCAD detail
Qt version: 5.9.7
Re: animation wb. outputting images to file
Postby chrisb » Mon Aug 12, 2019 3:57 pm
Microelly is the author of Animation workbench
microelly wrote:ping
bzb.dev001
Postby bzb.dev001 » Mon Aug 12, 2019 4:50 pm
How do I ping someone using this forum?
TheMarkster
Postby TheMarkster » Mon Aug 12, 2019 6:11 pm
(without the space after the first bracket)
[ quote=bzb.dev001 user_id=25224]
ping
[/quote]
My FreeCAD video series on youtube: https://www.youtube.com/playlist?list=P ... 48TYSI7GET
bzb.dev001
Postby bzb.dev001 » Thu Aug 15, 2019 12:25 pm
I'm going to log this as a bug. Any objections?
Postby chrisb » Thu Aug 15, 2019 12:38 pm
Any objections?
Yes!
Animation workbench is not part of FreeCAD, it is an addon. Perhaps you can discuss this issue on the homepage of the animation workbench, but the FreeCAD bugtracker sure is the wrong place. And I would guess that microelly2 would not be aware of an issue there.
Postby Kunda1 » Thu Aug 15, 2019 2:29 pm
TheMarkster
Postby TheMarkster » Fri Aug 16, 2019 10:48 pm
Possibly it is a python3 issue. Try one of the python2 builds of FreeCAD.
bzb.dev001
Postby bzb.dev001 » Sun Aug 18, 2019 3:54 pm
Can you direct me to the download location. I'm using Ubuntu.
I couldn't find any binary downloads. I looked at ...
https://github.com/FreeCAD/FreeCAD
https://www.freecadweb.org/wiki/Download
https://github.com/FreeCAD/FreeCAD/releases
