Tips on improving techdraw performance
freedman
Re: Tips on improving techdraw performance
Postby freedman » Thu Aug 15, 2019 10:05 pm
Not trying to buzz kill, Isn't the hard part of this getting dimensions, end points, arcs, ect. And could this be a DXF instead of a SVG?
Thanks.
yorik
Site Admin
Postby yorik » Thu Aug 15, 2019 10:12 pm
One issue at a time please :D
freedman
Postby freedman » Thu Aug 15, 2019 10:40 pm
Sorry, I was actually trying to make less work. I thought the DXF format was created to rid the issues of trying to convert dots into lines. The svg format is not very easy to use when it comes to creating dimensions. Please proceed.. :)
yorik
Site Admin
Postby yorik » Thu Aug 15, 2019 11:27 pm
Ok I found a way to scale!
New version of the script, it should now work with any FreeCAD model. Just open a model, set the camera to your liking, and fire the script! (it can be saved as a macro too)
import FreeCAD,FreeCADGui
from pivy import coin
from PySide import QtCore,QtGui
import os,re,math,tempfile
import TechDraw
# a name to save a temp file
svgfile = tempfile.mkstemp(suffix=".svg")[1]
# set object lighting to single face to get black fills
# but this creates artifacts in svg output, triangulation gets visible...
#ldict = {}
#for o in FreeCAD.ActiveDocument.Objects:
#    if hasattr(o,"ViewObject") and hasattr(o.ViewObject,"Lighting"):
#        ldict[o.Name] = o.ViewObject.Lighting
#        o.ViewObject.Lighting = "One side"
# get nodes to render
sg = FreeCADGui.ActiveDocument.ActiveView.getSceneGraph()
ac = FreeCADGui.ActiveDocument.ActiveView.getCamera()
rn = coin.SoSeparator()
for n in sg.getChildren():
    if isinstance(n,coin.SoSeparator):
        ncopy = n.copy()
        rn.addChild(ncopy)
# reset lighting of objects
#    if o.Name in ldict:
#        o.ViewObject.Lighting = ldict[o.Name]
# create viewer
v = FreeCADGui.createViewer()
if hasattr(v,"setName"):
    v.setName("RenderViewer")
vv = v.getViewer()
vv.setBackgroundColor(1,1,1)
v.redraw()
# set clip plane
#clip = coin.SoClipPlane()
#clip.on = True
#plane = coin.SbPlane(coin.SbVec3f(1,0,0),5000) #dir, position on dir
#clip.plane.setValue(plane)
#rn.insertChild(clip,0)
# set scenegraph
vv.setSceneGraph(rn)
# set camera
#c = '#Inventor V2.1 ascii\n\n\nOrthographicCamera {\n  viewportMapping ADJUST_CAMERA\n  position -36733.652 -7668.0435 256.88913\n  orientation -0.57735038 0.57735038 0.57735038  4.1887903\n  nearDistance 5128.5186\n  farDistance 76777.062\n  aspectRatio 1\n  focalDistance 40917\n  height 11075.028\n\n}\n'
v.setCamera(ac)
# get the viewer's mdi subwindow
mdi = None
mw = FreeCADGui.getMainWindow()
for sw in mw.findChildren(QtGui.QMdiSubWindow):
    if sw.windowTitle() == "RenderViewer":
        mdi = sw
        break
# save view
v.saveVectorGraphic(svgfile,1) # number is pixel size
# fix linewidths - the 1px default one is a bit too big...
f = open(svgfile,"r")
svg = f.read()
f.close()
svg = svg.replace("stroke-width:1.0;","stroke-width:0.2;")
svg = svg.replace("stroke-width=\"1px","stroke-width=\"0.2px")
# get 3D view dimensions, and calculate scale factor
factor = 1
if mdi:
    ww = mdi.width()
    wh = mdi.height()
    p1 = v.getPoint(0,0)
    p2 = v.getPoint(ww,wh)
    diag = (p2.sub(p1)).Length
    vpdim = re.findall("width=\"(.*?)\" height=\"(.*?)\"",svg)
    if vpdim:
        vpw = float(vpdim[0][0])
        vph = float(vpdim[0][1])
        vpdiag = math.hypot(vpw,vph)
        factor = diag/vpdiag
        #print("mdi:",ww,wh,"vp:",vpw,vph,"factor:",factor)
# remove background rectangle
svg = re.sub("<path.*?>","",svg,count=1,flags=re.MULTILINE|re.DOTALL)
# embed everything in a scale group and scale the viewport
if factor != 1:
    svg = svg.replace("<g>","<g transform=\"scale("+str(factor)+","+str(factor)+")\">\n<g>",1)
    svg = svg.replace("</svg>","</g>\n</svg>")
    svg = re.sub("width=\""+vpdim[0][0]+"\"","width=\""+str(vpw*factor)+"\"",svg,count=1,flags=re.MULTILINE|re.DOTALL)
    svg = re.sub("height=\""+vpdim[0][1]+"\"","height=\""+str(vph*factor)+"\"",svg,count=1,flags=re.MULTILINE|re.DOTALL)
# save result
#f = open(svgfile,"w")
#f.write(svg)
#f.close()
# close viewer
if mdi:
    mdi.close()
# find or create TD page
pages = FreeCAD.ActiveDocument.findObjects("TechDraw::DrawPage")
if pages:
    page = pages[0]
else:
    page = FreeCAD.ActiveDocument.addObject('TechDraw::DrawPage','Page')
    template = FreeCAD.ActiveDocument.addObject('TechDraw::DrawSVGTemplate','Template')
    template.Template = os.path.join(FreeCAD.getResourceDir(),'Mod/TechDraw/Templates/A4_LandscapeTD.svg')
    page.Template = template
view = FreeCAD.ActiveDocument.addObject('TechDraw::DrawViewSymbol','RenderedView')
view.Symbol = svg
# calculate a rough scale factor...
view.Scale = 1000.0/(vpw*factor)
page.addView(view)
FreeCAD.ActiveDocument.recompute()
It now scales things correctly (there might be imprecision due to the SVG viewport size being an int, needs further testing), and supports lines and texts and dimensions too, although the text get exploded/rendered. This will need to get bettered at some point. But it's becoming quite powerful..
Screenshot from 2019-08-15 20-19-01.png (146.44 KiB) Viewed 548 times
Postby Kunda1 » Fri Aug 16, 2019 12:39 am
This is a whole new level of kickbutt-ness! :clap::clap::clap:
vocx
Postby vocx » Fri Aug 16, 2019 2:46 am
The way it's done by many in FreeCAD, is that you add the dimensions using Draft Dimension on the 3D model itself. Then, in TechDraw you just show those dimensions. You don't add more dimensions there.
freedman
Postby freedman » Fri Aug 16, 2019 3:17 am
Thanks vocx, I was looking at those dims and I couldn't figure out how they were placed.
Yorik, when I ran the code as a macro I had to comment out.
line 39, in <module>  v.setBackgroundColor(1,1,1) <type 'exceptions.AttributeError'>: setBackgroundColor
wandererfan
Postby wandererfan » Fri Aug 16, 2019 1:28 pm
yorik wrote:
Thu Aug 15, 2019 3:31 pm
So I think before passing the SVG to the ViewSymbol, we'll need to scale it properly, but I suppose it shouldn't be hard to either convert the C++ code you're referring to, or make a python binding for it. Only, I couldn't locate that code, could you give me some direction?
If I remember rightly, this code determines the real world size of the viewport in mm, then computes a scale that corrects the generated image to be the right size in TD. It is working on bit maps, but the principle should be the same for Svg.
        Gui::View3DInventor* view3d = qobject_cast<Gui::View3DInventor*>(mdi3d);
        if (view3d != nullptr) {
            Base::Console().Message("G3d::grab3dView - have a view3d\n");
            Gui::View3DInventorViewer* viewer = view3d->getViewer();
            if (viewer == nullptr) {
                Base::Console().Message("G3d::grab3dView - no V3DIV\n");
                return result;
            SbVec2s vpsize = viewer->getSoRenderManager()->getViewportRegion().getViewportSizePixels();
            vpWpx= vpsize[0];  //viewport size in pixels
            vpHpx = vpsize[1];
            //save picture as vpWpxx x vpHpx rectangle.  ie same as screen
            viewer->savePicture(vpWpx, vpHpx, 8, bg, img);     //what is magic number 8? a page size?
            //determine scale of 3dView bitmap
            SoCamera * const camera = viewer->getSoRenderManager()->getCamera();
            if (!camera) {
                Base::Console().Message("G3d::grab3dView - no camera\n");
                return result;
            double heightmm = 0.0;
            double angle = 0.0;
            double focalDistance = camera->focalDistance.getValue();
            if (camera->getTypeId() == SoOrthographicCamera::getClassTypeId()) {
                Base::Console().Message("G3d::grab3dView - camera is ortho\n");
                SoOrthographicCamera* oCam = dynamic_cast<SoOrthographicCamera*>(camera);
                heightmm = oCam->height.getValue();
                angle = M_PI / 4.0;              //45*
            } else if (camera->getTypeId() == SoPerspectiveCamera::getClassTypeId()) {
                Base::Console().Message("G3d::grab3dView - camera is persp\n");
                SoPerspectiveCamera* pCam = dynamic_cast<SoPerspectiveCamera*>(camera);
                angle = pCam->heightAngle.getValue();
                heightmm = tan(angle / 2.0) * focalDistance * 2.0;
            } else {
                msg = QT_TR_NOOP("Grabber::grab3dView - camera is Unknown");
                msg += "\n";
                Base::Console().Warning(msg.c_str());
                return result;
            double vpmmppx = heightmm/vpHpx;  //height in mm / viewport height in px  = mm/px
            double preScale = vpmmppx/tdmmppx;  //this is pretty good as a prescaler to size for TD
            feat->PreScale.setValue(preScale);
wandererfan
Postby wandererfan » Fri Aug 16, 2019 1:33 pm
I'm late to the party again. :(
yorik
Site Admin
Postby yorik » Fri Aug 16, 2019 1:43 pm
Great thanks!! Easy to convert to python. One thing, though, this code has the same limitation as the one I'm using now: the view size is obtained in pixels, which could give quite a lot of imprecision (enough to change the value of a dimension, for ex). But I suppose we'll have to live with it for now, there might be further checks we can apply later on to refine the scale factor.
You are running 0.18 probably... This was added later I think.
One issue with the code above, is that texts are decomposed into many triangles (on the image in my last post, turning the dimension on doubles the size of the svg file and makes TD significantly slower). However, adding texts in SVG is simple and fast. Maybe we need some extra processing there, remove texts from the coin graph and re-add them manually... Lots of room for improvement!
