Import Stp file option missing on V 0.18
Version: 0.18.16131 (Git)
Branch: releases/FreeCAD-0-18
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 3.6.6
Qt version: 5.6.2
Hi Guys...thanks for the help last time. I am slowly getting a little better, but this is no where near what I do all the time...so I remain bad
I down loaded the above version (although I have a video on importing stp file in v 0.19) but cannot find v 0.19.
I would like to import a stp file. I watch the video, it says:
edit
Preferences
Import-Export.....this is were it all goes bad....the video shows these options: DXF, DWG, SVG, OCA, DAD Exchanger, Abaqus VTK, IGES, STEP.....
Mine shows: IFC, DAE, DXF, DWG, SVG and OCA.
So no step???
Can anyone help??
Thank you
Dan
Qt version: 5.6.2
edit
Preferences
So no step???
Can anyone help??
Thank you
Dan
- 2019-08-14-NoStep.JPG (88.24 KiB) Viewed 1102 times
Re: Import Stp file option missing on V 0.18
0.19 is here: https://github.com/FreeCAD/FreeCAD/rele ... g/0.19_pre
Change to Part or Part Design workbenches and check again
Guys
Fabulous I used Part and it worked. Thank you.
I am now interested in 0.19....but when I went to the link it downloaded "FreeCAD-master,zip". Not as the previous that was "freeCAD-018.16131.3129ae4-WIN-x64-installer.exe
Did i hit the wrong hyperlink??
Thank you.
Dan
Thank you.
Dan
Only the latest stable has installable .exe format available.
For the current pre release version you can get one of the zip files, extract it, then look for FreeCAD.exe in the bin folder. There is no need to install.
Sir
Thank you for the tip on v 01.9. But I searched in the unziped files and I could not find FreeCad.exe or the bin folder.
I suppose just wait for the real one...ha-ha
Thank you
Thank you
You need some of those:
They are 7z archives and you will need 7-zip to extract them. You should try Py3Qt5 buils because Py2Qt4 ones will be discarded in the future.
Gentlemen,
Thank you.
But I am totally confused...I downloaded and upziped:
FreeCAD_0.19-17515_x64_Conda_Py3QT5-WinVS2015.7z: and
FreeCAD_0.19-17515_x64_LP_12.1.2.PY3QT5-WinV2015.7z: and
FreeCAD-master.zip
They all unziped into their own folders. There were a number of FreeCAD.exe file and I clicked on one and it appeared to open.
It looks very messy....what have I done wrong??
Dan
Thank you.
FreeCAD-master.zip
Dan
They are different builds. You need just one of them extracted. Run its FreeCAD exe and if it runs Ok keep it. When in the future there is a new build that you want to try (because it has a new feature, fixes a bug you encounter,...) again download the latest build, extract and try. But keep some old working builds in case something in the new one makes it crash on your system.
Sir
OK, I understand. Not really sure what happened.
But thank you.
Have a good night
Dan
But thank you.
Have a good night
Dan
