Lost workbench dropdown from UI
falviani
Postby falviani » Sat Aug 17, 2019 2:45 pm
My setup:
OS: Windows 10 (10.0)
Version: 0.19.17651 (Git)
Hash: 16c26cb3b1cd7209ea8efc8cb30b3b18fd80cf95
Python version: 3.6.8
Qt version: 5.12.1
I've been working on trying to do some non-text engraving in the path module (but that's another story) and when I opened FreeCAD this morning after turning on experimental features yesterday I do not have the drop down of workbenches in the UI. Turning off the experimental features and restarting had no effect. Trying the previous version I had (version 505) had no effect. I suspect something in the persistent settings has been updated/corrupted. How do I get the workbench drop down back? I've attached a screenshot of the current parameter settings (which also shows the lack of drop down menu..)
Thanks in advance,
Frank Alviani
Parameter settings.png (137.2 KiB) Viewed 279 times
kisolre
Re: Lost workbench dropdown from UI
Postby kisolre » Sat Aug 17, 2019 4:06 pm
RMB on area where toolbars should be, select appropriate toolbar?
TheMarkster
Postby TheMarkster » Sat Aug 17, 2019 4:53 pm
In Edit menu -> preferences look for the reset button on the lower left. I think this resets all user preferences.
If that fails you can try renaming/deleting your config files. There is a macro findConfigFiles that can help locate them if you don't know where they are.
Check the view menu -> workbench as an alternative means of selecting a workbench.
My FreeCAD video series on youtube: https://www.youtube.com/playlist?list=P ... 48TYSI7GET
bejant
Postby bejant » Sat Aug 17, 2019 6:22 pm
From the pull-down menu try View > Toolbars, then tick Workbench (and the others you'd like to see) to True.
falviani
Postby falviani » Sat Aug 17, 2019 8:11 pm
Thought I had checked the toolbars submenu; obviously I hadn't. :oops: Thanks.
bejant
Postby bejant » Sun Aug 18, 2019 11:56 am
You're welcome, and I can tell you (from my own experience) that it's sometimes too easy to forget simple solutions.
