[Feature request] Clipping plane improvement
mario52
Re: [Feature request] Clipping plane improvement
Postby mario52 » Wed Aug 21, 2019 9:46 pm
hi
I do not know maybe the complexity of project !?
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
leoheck
Postby leoheck » Fri Aug 30, 2019 12:54 am
I still have this issue. Where can I to post this issue?
Postby chrisb » Fri Aug 30, 2019 5:49 am
The first thing to repair would be to remove the cyclic dependency in your model. Look at the Std DependencyGraph to find where it occurs.
freedman
Postby freedman » Sat Aug 31, 2019 3:57 am
I only work in Part Design. I make a quick clip-Pocket and slice the model in half and delete the clip when I'm done. I also use the clip to send to TechDraw. I hope papyblaise doesn't mind me using his plug just once, it's cool. Thank you.
saso
Postby saso » Sat Aug 31, 2019 7:05 am
triplus posted this in the "FreeCAD on the web" topic https://github.com/fougue/mayo check the clipping functionality in the screencast at the bottom of the page
leoheck
Postby leoheck » Wed Sep 04, 2019 8:17 pm
@crisp thank you for the suggestion, I need to understand modeling better. I am still not mature enough on Freecad.
@thanks freedman, this is actually a good way to work around it.
@saso, is it the right URL you wanted to share?
Some guys helped me to report this issue on the macro. It is working for me now.
https://forum.freecadweb.org/viewtopic.php?f=8&t=38946
kisolre
Postby kisolre » Wed Sep 04, 2019 8:27 pm
It is the correct link. At the bottom of the page there is a Screencast section with a long gif which shows the clipping functionality.
Postby chrisb » Wed Sep 04, 2019 10:59 pm
Parametric 3D modeling is indeed not easy at all. It is far more difficult than e.g. using a 2D vector graphic program. My recommendation: Follow the forum, try to find solutions to the modeling questions posed here; compare your solutions to those given from other users.
And if questions occur with your model, then you can always ask yourself.
HarryGeier
Postby HarryGeier » Mon Sep 09, 2019 9:56 am
I tried too about 2 weeks ago..still have the error.. i once modified it for me so it works ( 0.18 /Windows )
if wanted i can post it back here..
Kaum macht man´s richtig , gehts´s
My Video Tutorials on Youtube: https://www.youtube.com/channel/UCoe3B ... p8Q/videos
My FreeCAD Stuff on Hidrive: https://my.hidrive.com/share/qr3l1yddy6#$/
looo
Postby looo » Mon Sep 09, 2019 11:37 am
There is a way to add faces to clipped solids with opengl. If I remember correctly this works by drawing the backside and removing the frontside [1] of closed meshes.
[1] https://forum.freecadweb.org/viewtopic. ... 88#p170708
