Arch Building Part still touched after recompute
furti
Postby furti » Fri Aug 23, 2019 2:36 pm
I performed the following steps:
1. Create a new document
2. Switch to Arch Workbench
2. Create a Building
3. Crate a Building Part
4. Move the Building Part into the building
5. Create a Wall
6. Move the Wall into the Building Part
Now the Building Part gets marked for Recompution and the Report View displays the following Message
466.375 <App> Document.cpp(3134): Unnamed#BuildingPart001 still touched after recompute
Clicking Recompute gives the same message over and over again. Only the Number at the beginning changes.
Don't know what this stands for. It looks like it depends on the actual time? Seems to be the seconds since the Document was created or something.
Tested with version
OS: Windows 10 (10.0)
Version: 0.19.17803 (Git)
Hash: 89961a33d46063a43e9fb5b0308ca95d559eca94
Python version: 3.6.8
Qt version: 5.12.1
Locale: German/Austria (de_AT)
furti
Re: Arch Building Part still touched after recompute
Postby furti » Sun Aug 25, 2019 5:28 am
yorik wrote: ping
Any news on this? It is a bit annoying on bigger projects as adding a single object performs a recompute on the Building Parts and that needs about 10 to 20 seconds to finish. :(
yorik
Site Admin
Postby yorik » Mon Aug 26, 2019 2:48 pm
Yes this came after the link3 merge I believe, probably something to do with the group extension... But I couldn't narrow the problem down any further yet...
Here is a simple test file in the meantime that shows the problem: An Arch structure inside an Arch BuildingPart inside another Arch BuildingPart. The "middle" building part always stays touched. If you remove the parent one, all works again
column.FCStd
(14.25 KiB) Downloaded 33 times
DeepSOIC
Postby DeepSOIC » Mon Aug 26, 2019 3:16 pm
I think this may be caused by the new recompute logic.
https://github.com/realthunder/FreeCAD_ ... s#document
Add support for some form of dependency inversion using a two-pass iteration. ...
The two-pass recomputation works like this. The first pass proceed as normal. After its done, any object that is still touched will be marked with a newly added ObjectStatus::Recompute2 flag. The second pass will then be launched. Those objects that need dependency inversion shall check its dependent objects for this flag, and do not touch them if found. If there are still objects touched after the second pass, an error message will be printed.
danreb
Postby danreb » Thu Aug 29, 2019 5:24 am
FYI same poblem with
  • BuidingPart (Site/building/buildingpart/level)
    • Group
      • Structure
==> the group stays touched after recompute
But no problem with
  • Group
      • Structure
yorik
Site Admin
Postby yorik » Thu Aug 29, 2019 3:05 pm
An same with this scenario too:
Screenshot from 2019-08-29 12-03-57.png (8.88 KiB) Viewed 1146 times
danreb
Postby danreb » Fri Aug 30, 2019 6:24 am
does "recompute" only recompute Visible objects?
When you set the parent BuildingPart to visible=false and child Buildingpart to visible= true (or both objects to visible=false), then the objects computation is ok with no errors.
But setting the Parent and child visibility to false and then setting the parent visibility to "true" it triggers the visibility on all subObjects which are all marked "to recompute". But then I am unable to set the child BuildingPart visibility to false .
yorik
Site Admin
Postby yorik » Tue Sep 03, 2019 3:13 am
Recompute should recompute no matter if the object is visible or not. But indeed if I turn everything invisible I'm able to recompute too.
Definitely something buggy in there...
danreb
Postby danreb » Tue Sep 10, 2019 9:33 am
Hi Is there a way I could help solving this issue (I am afraid not much more but if it is please ask)?
Indeed I am stuck with the following release untill this "recompute bug" is solved
OS: macOS 10.14
Version: 0.19.17681 (Git)
Hash: e94af7ff5e873f263cac51d7d47df68eca183250
Python version: 3.7.3
Qt version: 5.9.7
Locale: French/France (fr_FR)
And I would like to work with and test the later releases from freecad which show core features/concept remodeling and improvement (e.g. object recomputation and object/group hierarchy handling)....with sides effect that I would like to highlight and test further in my project files. cf https://forum.freecadweb.org/viewtopic. ... 59#p329859
thanks
vocx
Postby vocx » Sat Sep 28, 2019 8:22 pm
realthunder wrote:Add support for some form of dependency inversion using a two-pass iteration. ...
realthunder wrote:
Fri Sep 27, 2019 1:35 pm
ping
Hi, realthunder, since you seem to be back, is it possible that you look into this?
This is another thread with a similar behavior, but we aren't sure if this is a problem in Arch objects, or in the way the new tree view and selection works, [ Bug ? ] In floor object only one nested object can be invisible?
The issue still occurs in the latest code.
OS: Ubuntu 18.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.18351 (Git)
Build type: Debug
Hash: fb7a03a04d04e770305f96a31b608d6951d927c8
Qt version: 5.9.5
cron
