OCCError: Failed to create face from wire
freman
Postby freman » Sun Aug 25, 2019 7:42 am
I want to mark out a degree disc, so I thought draft would be the right WB to start in. I drew a circle as the base and then tried to mark a straight horizontal line coming off it, with the intention to rotate this to get the other marks.
Sadly, down at the first hurdle. It can draw a line but if I start the line on the circle it barfs.
Pick first point
Pick next point
PathCommands.ERROR: Failed to create face from wire
  File "/svn/freecad19-master-build/Mod/Path/PathCommands.py", line 71, in IsActive
    self.active = self.formsPartOfALoop(sel.Object, sel.SubObjects[0], sel.SubElementNames)
  File "/svn/freecad19-master-build/Mod/Path/PathCommands.py", line 111, in formsPartOfALoop
    if len(names) == 1 and horizontalEdgeLoop(obj, sub):
  File "/svn/freecad19-master-build/Mod/Path/PathScripts/PathUtils.py", line 245, in horizontalEdgeLoop
    loops = [w for w in wires if all(PathGeom.isHorizontal(e) for e in w.Edges) and PathGeom.isHorizontal(Part.Face(w))]
This looks like a bug, but maybe I'm missing something and there is reason for this. Can anyone explain?
TIA.
OS: Linux (LXDE/LXDE)
Version: 0.19.16988 (Git)
Build type: Unknown
Hash: ff7975291d33a88e6a8282b88a62dbcbcc01ba2b
Python version: 2.7.15
kisolre
Re: OCCError: Failed to create face from wire
Postby kisolre » Sun Aug 25, 2019 8:00 am
Maybe it should have "create face" set to false before adding this extra line?
freman
Postby freman » Sun Aug 25, 2019 8:36 am
thanks, were do I find that, I don't see that anywhere.
kisolre
Postby kisolre » Sun Aug 25, 2019 9:20 am
Sorry, no idea how to check/access that in python. I just remembered that draft objects have such option.Draft_Rectangle check near the end - "Make face" option
freman
Postby freman » Sun Aug 25, 2019 9:29 am
Thanks, I'm not asking about python, that is just the output from the report window when it fails.
What is this "end" you are referring to ?
EDIT,
Ah , I see you are referring to properties tab in the combo. Yes, the draft-line does have the by default.
kisolre
Postby kisolre » Sun Aug 25, 2019 9:30 am
End of that wiki page?!?
freman
Postby freman » Sun Aug 25, 2019 9:43 am
If I select the line in the tree view, no error. If I select on the draft image I get the errors and it shows as selected.
It seems that all this may be spurious "non error" anyway despite all the scary red error messages.
Rotate tool seems equally unfinished and wiki is out of date.
