Tick #4099 - Crash on Wall create (because of faulty DXF which crashes FC)
Im trying to work with BIM WB and experience a few issues. What I did was:
- Import DXF files with floor plans
- Move plans in stack with floor height distance in between
Everything went fine but after all done I start notice some strange things
Weired rendering
While rotate and zoome some parts of plans become invisble and on another angle/zoom appears again. Also it appears if mouse cross some (even invisible) line. Not sure if that is a bug or something wrong with my rendering settings, help needs as it is quite annoying
Crash
Now when I get used with rendering behaviour I was trying to create a wall:
- Select some wire on the basement floor and press "wall". FC crashed, that a bit more annoying then missing lines on a plan
Here is bug report with file to reproduce the problem, system info, crash stack trace and other details:
- https://www.freecadweb.org/tracker/view.php?id=4099
*UPD*: I've compiled GIT master - same problems on FreeCAD 0.19 Revision: 17903 (Git)
Weired rendering
Crash
Reason: Added ticket number to thread title
Re: Crash on Wall create
For such issues please always attach your full FreeCAD info as described in the IMPORTANT forum rules linked above.
Already did in linked issue. But I will duplicate here:
File causes issues Version info
Stack trace
OS: Arch Linux
Version: 0.18.16131 (Git)
Branch: makepkg
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 3.7.4
Qt version: 5.13.0
FreeCAD 0.18, Libs: 0.18R16131 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
(freecad:24592): Gtk-WARNING **: 10:07:25.573: Theme parsing error: gtk.css:2:116: Failed to import:
Error opening file /home/andrphi/.local/share/gnome-shell/extensions/no-title-bar@franglais125.gmail.com/stylesheet.css:
No such file or directory
(freecad:24592): Gtk-WARNING **: 10:07:25.573: Theme parsing error: gtk.css:3:122: Failed to import:
Error opening file /home/andrphi/.local/share/gnome-shell/extensions/no-title-bar@franglais125.gmail.com/stylesheet-tiled.css:
DraftGeomUtils.connect: unable to connect edges
<Line object> Vector (4960909.62788767, 1000671.647867698, 0.0) Vector (4960909.62788767, 1000681.647867698,
0.0)
<Line object> Vector (4960709.62788767, 1000681.647867698, 0.0) Vector (4960709.62788767, 1000441.647867698,
0.0)
<Line object> Vector (4960709.62788767, 1000441.647867698, 0.0) Vector (4961049.62788767, 1000441.647867698,
0.0)
<Line object> Vector (4960709.62788767, 1000671.647867698, 0.0) Vector (4960709.62788767, 1000681.647867698,
0.0)
<Line object> Vector (4960909.62788767, 1000681.647867698, 0.0) Vector (4960909.62788767, 1000641.647867698,
0.0)
<Line object> Vector (4960909.62788767, 1000641.647867698, 0.0) Vector (4961049.62788767, 1000641.647867698,
0.0)
DraftGeomUtils: unable to bind wires
<Line object> Vector (4961029.627887671, 1000671.647867698, 0.0) Vector (4961029.627887671,
<Line object> Vector (4960829.627887671, 1000681.647867698, 0.0) Vector (4960829.627887671,
1000541.647867698, 0.0)
<Line object> Vector (4960829.627887671, 1000671.647867698, 0.0) Vector (4960829.627887671,
<Line object> Vector (4961029.627887671, 1000681.647867698, 0.0) Vector (4961029.627887671,
<Line object> Vector (4960829.627887671, 1000801.647867698, 0.0) Vector (4960829.627887671,
1000791.647867698, 0.0)
<Line object> Vector (4961029.627887671, 1000791.647867698, 0.0) Vector (4961029.627887671,
1000931.647867698, 0.0)
<Line object> Vector (4961029.627887671, 1000801.647867698, 0.0) Vector (4961029.627887671,
<Line object> Vector (4960829.627887671, 1000791.647867698, 0.0) Vector (4960829.627887671,
<Line object> Vector (4968449.627887669, 1002001.647867698, 0.0) Vector (4968449.627887669,
1001991.647867698, 0.0)
<Line object> Vector (4968649.627887669, 1001991.647867698, 0.0) Vector (4968649.627887669,
1002131.647867698, 0.0)
<Line object> Vector (4968649.627887669, 1002001.647867698, 0.0) Vector (4968649.627887669,
<Line object> Vector (4968449.627887669, 1001991.647867698, 0.0) Vector (4968449.627887669,
<Line object> Vector (4969359.62788767, 1006881.647867699, 0.0) Vector (4969214.342010461,
<Line object> Vector (4969214.342010461, 1006881.647867699, 0.0) Vector (4968097.047477968,
1005548.0008129562, 0.0)
<Line object> Vector (4968097.047477968, 1005548.0008129562, 0.0) Vector (4968097.047477968,
1005411.647867698, 0.0)
<Line object> Vector (4968097.047477968, 1005411.647867698, 0.0) Vector (4967539.627887675,
<Line object> Vector (4967539.627887675, 1005411.647867698, 0.0) Vector (4967539.627887669,
1004661.647867698, 0.0)
<Line object> Vector (4967539.627887669, 1004661.647867698, 0.0) Vector (4968329.62788767,
<Line object> Vector (4968329.62788767, 1004661.647867698, 0.0) Vector (4968329.62788767, 994461.6478676982,
0.0)
<Line object> Vector (4968329.62788767, 994461.6478676982, 0.0) Vector (4967719.62788767, 994461.6478676982,
0.0)
<Line object> Vector (4967719.62788767, 994461.6478676982, 0.0) Vector (4967719.62788767, 993711.6478676982,
0.0)
<Line object> Vector (4967719.62788767, 993711.6478676982, 0.0) Vector (4968069.62788767, 993711.6478676982,
0.0)
<Line object> Vector (4968069.62788767, 993711.6478676982, 0.0) Vector (4968069.627887673,
992261.6478676983, 0.0)
<Line object> Vector (4968069.627887673, 992261.6478676983, 0.0) Vector (4969359.62788767,
992261.6478676982, 0.0)
<Line object> Vector (4969359.62788767, 992461.6478676982, 0.0) Vector (4968719.62788767, 992461.6478676982,
0.0)
<Line object> Vector (4969359.62788767, 1006681.647867699, 0.0) Vector (4969307.698343353,
<Line object> Vector (4969307.698343353, 1006681.647867699, 0.0) Vector (4968297.047477968,
1005475.2949224397, 0.0)
<Line object> Vector (4968297.047477968, 1005475.2949224397, 0.0) Vector (4968297.047477968,
1005211.647867698, 0.0)
<Line object> Vector (4968297.047477968, 1005211.647867698, 0.0) Vector (4967739.627887673,
<Line object> Vector (4967739.627887673, 1005211.647867698, 0.0) Vector (4967739.627887671,
1004861.647867698, 0.0)
<Line object> Vector (4967739.627887671, 1004861.647867698, 0.0) Vector (4968529.62788767,
<Line object> Vector (4968529.62788767, 1004861.647867698, 0.0) Vector (4968529.62788767, 994261.6478676982,
0.0)
<Line object> Vector (4968529.62788767, 994261.6478676982, 0.0) Vector (4967919.62788767, 994261.6478676982,
0.0)
<Line object> Vector (4967919.62788767, 994261.6478676982, 0.0) Vector (4967919.62788767, 993911.6478676982,
0.0)
<Line object> Vector (4967919.62788767, 993911.6478676982, 0.0) Vector (4968269.62788767, 993911.6478676982,
0.0)
<Line object> Vector (4968269.62788767, 993911.6478676982, 0.0) Vector (4968269.627887673,
992461.6478676983, 0.0)
<Line object> Vector (4968269.627887673, 992461.6478676983, 0.0) Vector (4969359.62788767,
<Line object> Vector (4969359.62788767, 992261.6478676982, 0.0) Vector (4968719.62788767, 992261.6478676982,
0.0)
#0 /usr/lib/libc.so.6(+0x3a7e0) [0x7f0a75e8e7e0]
#1 0x7f0a04b7f798 in Geom_TrimmedCurve::Geom_TrimmedCurve(opencascade::handle<Geom_Curve> const&,
double, double, bool, bool) from /usr/lib/libTKG3d.so.7+0x1b8
0000002 0x7f09fb92c7db in GC_MakeSegment::GC_MakeSegment(gp_Pnt const&, gp_Pnt const&) from /usr/lib/libTKGeomBase.so.7+0xeb
0000003 0x7f0a01d8fcc4 in Part::LineSegmentPy::PyInit(_object*, _object*) from /usr/lib/freecad/lib/Part.so+0x984
0000004 /usr/lib/libpython3.7m.so.1.0(_PyObject_FastCallKeywords+0x11a) [0x7f0a76ef2f5a]
0000005 /usr/lib/libpython3.7m.so.1.0(+0x138362) [0x7f0a76ef4362]
0000006 /usr/lib/libpython3.7m.so.1.0(_PyEval_EvalFrameDefault+0x4fda) [0x7f0a76f2e40a]
0000007 /usr/lib/libpython3.7m.so.1.0(_PyEval_EvalCodeWithName+0x2f8) [0x7f0a76ee2768]
0000008 /usr/lib/libpython3.7m.so.1.0(_PyFunction_FastCallKeywords+0x2a3) [0x7f0a76ee37d3]
0000009 /usr/lib/libpython3.7m.so.1.0(+0x1381d0) [0x7f0a76ef41d0]
0000010 /usr/lib/libpython3.7m.so.1.0(_PyEval_EvalFrameDefault+0x1748) [0x7f0a76f2ab78]
0000011 /usr/lib/libpython3.7m.so.1.0(_PyEval_EvalCodeWithName+0x2f8) [0x7f0a76ee2768]
0000012 /usr/lib/libpython3.7m.so.1.0(_PyFunction_FastCallKeywords+0x2a3) [0x7f0a76ee37d3]
0000013 /usr/lib/libpython3.7m.so.1.0(+0x1381d0) [0x7f0a76ef41d0]
0000014 /usr/lib/libpython3.7m.so.1.0(_PyEval_EvalFrameDefault+0x4fda) [0x7f0a76f2e40a]
0000015 /usr/lib/libpython3.7m.so.1.0(_PyEval_EvalCodeWithName+0x2f8) [0x7f0a76ee2768]
0000016 /usr/lib/libpython3.7m.so.1.0(_PyFunction_FastCallKeywords+0x2a3) [0x7f0a76ee37d3]
0000017 /usr/lib/libpython3.7m.so.1.0(+0x1381d0) [0x7f0a76ef41d0]
0000018 /usr/lib/libpython3.7m.so.1.0(_PyEval_EvalFrameDefault+0xb40) [0x7f0a76f29f70]
0000019 /usr/lib/libpython3.7m.so.1.0(_PyEval_EvalCodeWithName+0x2f8) [0x7f0a76ee2768]
0000020 /usr/lib/libpython3.7m.so.1.0(_PyFunction_FastCallDict+0x2ef) [0x7f0a76ee3e7f]
0000021 /usr/lib/libpython3.7m.so.1.0(_PyObject_Call_Prepend+0x68) [0x7f0a76eb7ce8]
0000022 /usr/lib/libpython3.7m.so.1.0(PyObject_Call+0x7e) [0x7f0a76ee43be]
0000023 0x7f0a77548f80 in App::FeaturePythonImp::execute() from /usr/lib/freecad/lib/libFreeCADApp.so+0x5d0
0000024 0x7f0a01d49fa7 in App::FeaturePythonT<Part::Feature>::execute() from /usr/lib/freecad/lib/Part.so+0x17
0000025 0x7f0a774f9589 in App::DocumentObject::recompute() from /usr/lib/freecad/lib/libFreeCADApp.so+0xb9
0000026 0x7f0a01d481ba in Part::Feature::recompute() from /usr/lib/freecad/lib/Part.so+0xa
0000027 0x7f0a774ac2b5 in App::Document::_recomputeFeature(App::DocumentObject*) from /usr/lib/freecad/lib/libFreeCADApp.so+0x55
0000028 0x7f0a774b589b in App::Document::recompute() from /usr/lib/freecad/lib/libFreeCADApp.so+0x19b
0000029 0x7f0a77528ef5 in App::DocumentPy::recompute(_object*) from /usr/lib/freecad/lib/libFreeCADApp.so+0x45
0000030 0x7f0a77528feb in App::DocumentPy::staticCallback_recompute(_object*, _object*) from /usr/lib/freecad/lib/libFreeCADApp.so+0x3b
0000031 /usr/lib/libpython3.7m.so.1.0(_PyMethodDef_RawFastCallKeywords+0x25f) [0x7f0a76ec25df]
0000032 /usr/lib/libpython3.7m.so.1.0(_PyCFunction_FastCallKeywords+0x24) [0x7f0a76ec2714]
0000033 /usr/lib/libpython3.7m.so.1.0(+0x1382ec) [0x7f0a76ef42ec]
0000034 /usr/lib/libpython3.7m.so.1.0(_PyEval_EvalFrameDefault+0x4fda) [0x7f0a76f2e40a]
0000035 /usr/lib/libpython3.7m.so.1.0(_PyFunction_FastCallDict+0x11b) [0x7f0a76ee3cab]
0000036 /usr/lib/libpython3.7m.so.1.0(_PyObject_Call_Prepend+0x68) [0x7f0a76eb7ce8]
0000037 /usr/lib/libpython3.7m.so.1.0(PyObject_Call+0x7e) [0x7f0a76ee43be]
0000038 /usr/lib/freecad/lib/libFreeCADBase.so(PP_Run_Method+0xec) [0x7f0a772c0e0c]
#39 0x7f0a77252bfc in Base::InterpreterSingleton::runMethodVoid(_object*, char const*) from /usr/lib/freecad/lib/libFreeCADBase.so+0x2c
#40 0x7f0a77b0925a in Gui::PythonCommand::activated(int) from /usr/lib/freecad/lib/libFreeCADGui.so+0xaa
0000041 0x7f0a77b0cb2c in Gui::Command::invoke(int) from /usr/lib/freecad/lib/libFreeCADGui.so+0x5c
0000042 0x7f0a764d6a11 in QMetaObject::activate(QObject*, int, int, void**) from /usr/lib/libQt5Core.so.5+0x7c1
0000043 0x7f0a76877e93 in QAction::triggered(bool) from /usr/lib/libQt5Widgets.so.5+0x43
0000044 0x7f0a7687a624 in QAction::activate(QAction::ActionEvent) from /usr/lib/libQt5Widgets.so.5+0x104
0000045 /usr/lib/libQt5Widgets.so.5(+0x253c2d) [0x7f0a76978c2d]
0000046 0x7f0a76978e56 in QAbstractButton::mouseReleaseEvent(QMouseEvent*) from /usr/lib/libQt5Widgets.so.5+0xe6
0000047 0x7f0a76a6dceb in QToolButton::mouseReleaseEvent(QMouseEvent*) from /usr/lib/libQt5Widgets.so.5+0xb
0000048 0x7f0a768c1cb6 in QWidget::event(QEvent*) from /usr/lib/libQt5Widgets.so.5+0x256
0000049 0x7f0a76a6dd95 in QToolButton::event(QEvent*) from /usr/lib/libQt5Widgets.so.5+0x35
0000050 0x7f0a7687e4d5 in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /usr/lib/libQt5Widgets.so.5+0x85
0000051 0x7f0a76887c6c in QApplication::notify(QObject*, QEvent*) from /usr/lib/libQt5Widgets.so.5+0x57c
0000052 0x7f0a77adac39 in Gui::GUIApplication::notify(QObject*, QEvent*) from /usr/lib/freecad/lib/libFreeCADGui.so+0x89
0000053 0x7f0a764aa9c2 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /usr/lib/libQt5Core.so.5+0x182
0000054 0x7f0a76886d4b in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*,
QWidget**, QPointer<QWidget>&, bool, bool) from /usr/lib/libQt5Widgets.so.5+0x1bb
0000055 /usr/lib/libQt5Widgets.so.5(+0x1b9211) [0x7f0a768de211]
0000056 /usr/lib/libQt5Widgets.so.5(+0x1bc154) [0x7f0a768e1154]
0000057 0x7f0a7687e4d5 in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /usr/lib/libQt5Widgets.so.5+0x85
0000058 0x7f0a76887a21 in QApplication::notify(QObject*, QEvent*) from /usr/lib/libQt5Widgets.so.5+0x331
0000059 0x7f0a77adac39 in Gui::GUIApplication::notify(QObject*, QEvent*) from /usr/lib/freecad/lib/libFreeCADGui.so+0x89
0000060 0x7f0a764aa9c2 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /usr/lib/libQt5Core.so.5+0x182
0000061 0x7f0a74693789 in QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*)
from /usr/lib/libQt5Gui.so.5+0x709
0000062 0x7f0a7469505b in QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*)
from /usr/lib/libQt5Gui.so.5+0x27b
0000063 0x7f0a7466d37c in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>)
from /usr/lib/libQt5Gui.so.5+0xbc
0000064 /usr/lib/libQt5XcbQpa.so.5(+0x6bfec) [0x7f0a70198fec]
0000065 /usr/lib/libglib-2.0.so.0(g_main_context_dispatch+0x294) [0x7f0a73a11cf4]
0000066 /usr/lib/libglib-2.0.so.0(+0x6ab11) [0x7f0a73a13b11]
0000067 /usr/lib/libglib-2.0.so.0(g_main_context_iteration+0x31) [0x7f0a73a13b51]
0000068 0x7f0a765029a3 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)
from /usr/lib/libQt5Core.so.5+0x63
0000069 0x7f0a764a95ec in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/libQt5Core.so.5+0x12c
0000070 0x7f0a764b1326 in QCoreApplication::exec() from /usr/lib/libQt5Core.so.5+0x96
0000071 0x7f0a77a674c3 in Gui::Application::runApplication() from /usr/lib/freecad/lib/libFreeCADGui.so+0x1753
0000072 freecad(main+0x6e7) [0x562892a60407]
0000073 /usr/lib/libc.so.6(__libc_start_main+0xf3) [0x7f0a75e7aee3]
0000074 freecad(_start+0x2e) [0x562892a6071e]
I think there are some issues with the DXF. Your plans are relatively far from the origin (X=5,000,000; Y=1,000,000). And using Std_ViewFitAll leads to a very zoomed out view indicating that there are perhaps some 'garbage' elements in 'outer space'.
Digging in the FCStd file (which is in fact a ZIP file) I find PartShape#.brp files containing -nan entries (I assume: NAN=not a number), which seems bad.
Can you perhaps post the DXF?
Here is original DXF, file is too big to insert on forum, so I've put it on google drive:
https://drive.google.com/file/d/1ivfKiv ... sp=sharing
And yes there are some import problems with it.
Also yesterday I was trying different import options and if I set "Import hatch boundaries as wires" and "*blocks" then FC stop crash on Wall object creation.
The DXF indeed has some issues.
I have fixed the file using BricsCAD. Here are my steps:
plans_old.dxf (your file)
plans_new.dwg
plans_new_R12.dxf
- Erase all elements on the layout (to get a smaller file).
- Erase all hatch patterns.
- Erase garbage dimensions near origin.
- Use the _Audit command: this fixes 250 errors (mainly: Value: Z coordinate - 2e+050).
- Use the _OverKill command: 125 overlapping entities or segment(s) are deleted.
- Move the plans closer to the origin.
- Use the _Purge command.
- Erase 3 polylines on the Defpoints layer.
- Save as dwg and save as R12 dxf.
plans_new.dwg
plans_new_R12.dxf
- plans.zip
- (293.27 KiB) Downloaded 52 times
That is amaizing, thanks a lot, now everything runs smooth.
Should I leave originl issue openned? From my perspective crash is not a good thing even if caused some messy drawings...
This is a special case: Bad DXF, results in bad import, results in unexpected error. But ideally a program should never crash.
I would leave the issue open but add the information that a bad DXF is probably the root cause.
Re: Tick #4099 - Crash on Wall create (because of faulty DXF which crashes FC)
Hi there!
I was trying to reproduce this crash, but I have been unable to (I have used Arc create wall).
OS: Ubuntu 18.04.4 LTS (MATE/mate)
Version: 0.19.
Branch: unknown
Hash: 8ed90c858645e7562d9534265b6025d39ab4ffd6
Python version: 3.6.9
Qt version: 5.9.5
Version: 0.19.
Branch: unknown
Qt version: 5.9.5
