Sketcher, tangent constraint bug
freecc
Postby freecc » Sat Aug 31, 2019 4:18 pm
Hello, I just wanted to make you aware of a bug in the sketcher with the tangent constraint. When I apply it often it removes end point constraints (or whatever it is called).
In the attached file make the tangent constraint to the semicircle to the right with the line which is on a 45 degree slope to see the bug.
hal.FCStd
(11.37 KiB) Downloaded 20 times
TheMarkster
Re: Sketcher, tangent constraint bug
Postby TheMarkster » Sat Aug 31, 2019 4:59 pm
If adding a tangency constraint causes a previously applied coincidence constraint to become redundant and if you have auto remove redundants checkbox checked this is what will happen -- the redundant coincidence constraint is removed. Uncheck auto remove redundants if you would prefer to manually remove redundant constraints.
My FreeCAD video series on youtube: https://www.youtube.com/playlist?list=P ... GEBlLshYGa
kisolre
Postby kisolre » Sat Aug 31, 2019 5:28 pm
I had previously observed similar behavior bit did not pay much attention. It looks like it fails with autoremoval and instead of just removing endpoints coincidence it also removes just applied end to end tangency. This looks as a bug to me. If Auto remove redundants is not checked everything works as expected.
OS: Windows 8.1 (6.3)
Version: 0.19.17877 (Git)
Hash: 1e19ef5be4735f4200eaf99ce9e487d2be6f4151
Python version: 3.6.8
Qt version: 5.12.1
Locale: Bulgarian/Bulgaria (bg_BG)
Postby chrisb » Sat Aug 31, 2019 5:29 pm
That's the supposed behaviour. There are different types of tangency: line/line or line/point or point/point. Sketcher ConstrainTangent.
Postby chrisb » Sat Aug 31, 2019 5:31 pm
Crosspost above. Will look at the example from OP.
Postby chrisb » Sat Aug 31, 2019 6:04 pm
Had a look at the file. Couldn't see anything unexpected. The coincidence plus line/line tangency is unstable and automatically replaced by point/point tangency.
OS: macOS High Sierra (10.13)
Version: 0.19.17904 (Git)
Hash: ffcac528d54195092a8ab2e9ab6f4ed39bcaebbc
Python version: 3.7.3
Qt version: 5.12.1
freecc
Postby freecc » Sat Aug 31, 2019 6:17 pm
Qt version: 5.12.1
I have this exact behaviour.
OS: Ubuntu 16.04.6 LTS
Version: 0.18.1.
Python version: 2.7.12
Locale: Swedish/Sweden (sv_SE)
kisolre
Postby kisolre » Sat Aug 31, 2019 6:37 pm
Did you had "Auto remove redundants" ticked? As I mentioned this happens with it On.
openBrain
Postby openBrain » Sat Aug 31, 2019 7:12 pm
IIRC, having coincidence + line/line tangency caused instability in the solver and thus there is an automated substitution to a point/point tangency.
2 things IMO could be improved :
* If you then delete the tangency (hence is a point/point one), it will also "remove" the coincidence between points.
* If you apply tangency in continuous mode, you get no warning. Below message box is displayed only in single mode
Postby chrisb » Sat Aug 31, 2019 7:17 pm
I have just tried with autoremove and can confirm the issue. I will prepare a simplified example. Usually I would wait for Abdullah to comment, but he seems rather busy with other stuff, so I will create a ticket.
