Did you had "Auto remove redundants" selected? Described behavior is with it activated.
Sketcher, tangent constraint bug
Re: Sketcher, tangent constraint bug
Same for me. I'm totally unable to reproduce a bug...
@chrisb ; @kisolre : may you use specific solver settings ???
Aren't those per sketch? First is the file from the OP so probably nothing specific set. The other is file from ChrisB so unless he has something specific...
But it is mainly connected with removing redundancies. Are there settings in the solver that govern this?
I will retry with a plain vanilla config.
I can reproduce the issue with both files AutoRemoveTangency.FCStd and AutoRemoveTangency2.FCStd. I used a completely new user.cfg. The only setting changed was in Sketcher to select the checkbox "Auto remove redundants".
I have upgraded my FreeCAD, so here are the infos again. The locale has changed due to the defaault config settings.
OS: macOS High Sierra (10.13)
Version: 0.19.17935 (Git)
Hash: bdc229f51e959caedf24459c1b9c9de7f6567298
Python version: 3.7.3
Qt version: 5.12.1
Qt version: 5.12.1
Very weird... I tested now more than twenty times, and can't reproduce...
OS: Ubuntu 18.04.3 LTS (KDE/plasma)
Version: 0.19. 2018/08/21
Python version: 3.6.8
Qt version: 5.9.5
Locale: French/France (fr_FR)
Any more testers around? Please? So we can see a pattern.
All 3 files work fine here. In all cases an 'end point to endpoint tangency' is applied and a coincident constraint is removed.
OS: Windows 8.1 (6.3)
Version: 0.19.17877 (Git)
Hash: 1e19ef5be4735f4200eaf99ce9e487d2be6f4151
Qt version: 5.12.1
