Sketcher, tangent constraint bug
Re: Sketcher, tangent constraint bug
Postby chrisb » Sat Aug 31, 2019 7:41 pm
kisolre wrote:
Sat Aug 31, 2019 5:28 pm
It looks like it fails with autoremoval and instead of just removing endpoints coincidence it also removes just applied end to end tangency.
It doesn't happen always. In the attached file the horizontal dimension is removed, which also is not what is expected. Because I was on the wrong track as well I give a recipe to reproduce:
- open Sketch in Sketcher
- check Auto remove redundants
- uncheck Auto upadate
- select arc and line - not any points!
- select tangent icon
Expected is a fully constrained sketch with a horizontal continuation of the arc. The length of the continuation should be 50.
Blue: edit
AutoRemoveTangency.FCStd
(3.27 KiB) Downloaded 15 times
kisolre
Postby kisolre » Sat Aug 31, 2019 7:47 pm
Confirmed here.
Tried also to replace horizontal dimension with length constraint. Then when tangency is applied vertical constraint is removed.
Postby chrisb » Sat Aug 31, 2019 7:51 pm
And here is the file reproducing the issue from OP. The procedure is exactly the same as in my previous post. Expected is a fully constrained sketch with a quarter of an arc. Instead the coincidence and the tangency are removed leaving the sketch with 3 DOF.
Please confirm that you see the same issue, then I will create a ticket.
AutoRemoveTangency2.FCStd
(3.58 KiB) Downloaded 19 times
kisolre
Postby kisolre » Sat Aug 31, 2019 7:54 pm
Confirmed
Postby chrisb » Sat Aug 31, 2019 7:59 pm
issue #4105. Thanks for the extremely fast cooperation!
kisolre
Postby kisolre » Sat Aug 31, 2019 8:30 pm
Link to forum post in the ticket is wrongly formated.
Postby Kunda1 » Sat Aug 31, 2019 9:49 pm
FTFY ;)
Postby chrisb » Sat Aug 31, 2019 10:33 pm
Hm; it looks normal to me, and it works. What is wrong with it?
openBrain
Postby openBrain » Sat Aug 31, 2019 10:36 pm
As said above, Kunda1 FTFY. :)
Hartwig
Postby Hartwig » Sun Sep 01, 2019 7:57 am
I tested all three files of the thread and all worked correctly for me.
OS: Windows 7 SP 1 (6.1)
Version: 0.19.17803 (Git)
Hash: 89961a33d46063a43e9fb5b0308ca95d559eca94
Python version: 3.6.8
Qt version: 5.12.1
