Grid from draft workbench doesn't go away
freecc
Postby freecc » Sun Sep 01, 2019 10:33 pm
Say I make a cube in part WB. Now I go to draft WB and create a polar or a rectangular matrix. A net appears in the background and this net doesn't disappear when I change WB.
I don't understand why this background net appears in the first place and that it never disappears can't be right.
I just wanted to make you aware about this and hope you fix it. It's been like this for a long time.
Reason: s/Net/Grid/
vocx
Re: Net from draft workbench doesn't go away
Postby vocx » Sun Sep 01, 2019 11:27 pm
I think you mean the grid: Draft ToggleGrid. You can turn it off if you want.
A grid is an extremely useful element in 2D drawing as it allows you to snap 2D elements like lines, rectangles, circles, etc., to precise points that are spaced a certain distance. In general it doesn't present a huge problem, which is why most people don't consider it a problem. It is however, mostly useful in the Draft Workbench, and other workbenches don't really use it.
Postby chrisb » Sun Sep 01, 2019 11:39 pm
The visibility is indeed a bit cumbersome. See issue #3817.
freedman
Re: Grid from draft workbench doesn't go away
Postby freedman » Mon Sep 02, 2019 4:06 pm
Maybe a little under utilized in Part Design. I haven't used these much but I will now.
