Hello, chrisb help me with pipe 2-in-1, but now can not make single body. I add boss and need chamfer to big edge for over hang 3d print with same on bottom 2 pipes. Is it possible?
OS: Linux Mint 19.2 (X-Cinnamon/cinnamon)
Version: 0.19.17499 (Git) AppImage
Python version: 3.7.3
Qt version: 5.9.7
How to make joined
How to make joined
I am taking EASL at night to make my English better. I use VPN for USA better searching
- papyblaise
Re: How to make joined
Hello
you can do chanfer 1.99mm , and filet sup at 5mm on the top
- filet.PNG (106.45 KiB) Viewed 836 times
Thank you but I can not chamfer that corner as it will cut through very thin to next inside pocket of 31mm radius. I can not make all longer as height of 2-in-1 is fixed. I can not make big boss section come down any more it stops at 28mm and will not pass over that line where I chamfer now.papyblaise wrote: ↑Mon Sep 02, 2019 4:50 pm you can do chanfer 1.99mm , and filet sup at 5mm on the top
I can not use fillet for 3d print over hang must be chamfer to print to look good.
You can do it with 2 chamfers plus a slightly prolonged collar.
- 0902-thick_cb.FCStd
- (261.61 KiB) Downloaded 33 times
- papyblaise
5mm isn't chanfer , but filet
on mine file
on mine file
Which model are you talking about? In my model are no fillets and two chamfers, one 3.8mm and another with 3.9.
