(I am new to freeCAD and somewhat also to CAD, so please bear with me.)
Is there a possibility in freeCAD to generate "customizeable parts"?
Customizeable parts should mean parts which have some constraints changeable after they being inserted into a construction.
My challenge:
I'd like to construct equipment using "squared pipes" (or profiles). So there is basically only one part which is the base profile. The only thing which changes in the application of the part is the lenght. So I I'd like to generate one profle part which I then can apply several times and only change the lenght of the part.
I have not found anything so far ( with the exception of pyhton scripts).
I would be glad if you could tell me if there is a solution to my questions and guide me to a description.
Thx.
