Shape rotation bug
baltic
Shape rotation bug
Postby baltic » Wed Sep 11, 2019 11:04 pm
Hi!
I have a sketch:
which i try to rotate around Z axis:
as a result, i get a non hollow solid. But it supposed to be hollow.
I have attached the file
My FreeCAD version is
OS: Ubuntu 18.04.3 LTS
Version: 0.18.16131 (Git) AppImage
Branch: (HEAD detached at 0.18.3)
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 3.6.7
Qt version: 5.6.2
test.FCStd
The buggy model
(4.09 KiB) Downloaded 23 times
jmaustpc
Re: Shape rotation bug
Postby jmaustpc » Wed Sep 11, 2019 11:11 pm
Please post your version data in the manner explained in the forum rules link above, when ever you want to ask for help for anything.
TheMarkster
Postby TheMarkster » Thu Sep 12, 2019 2:42 am
Line3 seems to be an extra line you don't need. When I delete it the revolve works as expected.
My FreeCAD video series on youtube: https://www.youtube.com/c/mwganson
Postby chrisb » Thu Sep 12, 2019 7:46 am
None of your lines in the sketch are connected. You should always try to fully constrain your sketches. Putting the geometric elements in the right place is usually not enough, in most cases you cannot create a feature at all.
baltic
Postby baltic » Thu Sep 12, 2019 8:34 am
Indeed! that helped. It was a 0 length line between two arcs on top (11-Arc, 12-Arc) After the arcs were made with fillet tool, the line became 0 length line and caused the trouble. I have reproduced this in a simple test, step by step.
Is it normal and there is a tool to refine such models by deleting 0 length lines? or is it a bug?
baltic
Postby baltic » Thu Sep 12, 2019 8:39 am
I've used "link end point elements with next elements starting points" tool. Which supposed to give connected lines, but it still did not solve the problem.
Postby chrisb » Thu Sep 12, 2019 10:06 am
I'm not aware of this tool. You can try "Validate Sketch", let the tool find coincidences by using appropriate tolerance and let it fix them.
baltic
Postby baltic » Thu Sep 12, 2019 3:33 pm
Alas the menu is always grayed out for me. No idea why
Postby chrisb » Thu Sep 12, 2019 3:54 pm
This happens if there is an active task. Switch to the task tab if this is the case and close it. If it is not the case, try switching workbenches to and fro.
easyw-fc
Postby easyw-fc » Thu Sep 12, 2019 6:53 pm
You may consider to have a try with StepUp Constrainator (it has a tool to constraint points and clean too short lines...)
