We created the boundary of a shape using curves wb. I couldn´t solve the triangle to surface problem (topic: mesh to surface, how to do?)
what´s the next step to get a surface. this surface is used as bottom and cover for a plate.
thank´s for help.
norusOS: Windows 10
Version: 0.18.16131 (Git)
Branch: releases/FreeCAD-0-18
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 3.6.6
Qt version: 5.6.2
curves wb, boundary to surface how to do
- FreeCAD_surface_mesh_2.PNG (103.76 KiB) Viewed 523 times
- FreeCAD_surface_mesh_1.PNG (71.78 KiB) Viewed 523 times
Re: curves wb, boundary to surface how to do
A test file would help.
Maybe you can switch to Surface workbench, use this joincurve as the boundary curve for a Filling surface, and add some vertex constraints inside the surface.
Or you can also try to generate a point-cloud object from the surface mesh and use the Reverse Engineering WB to approximate a surface on it.
thank you Chris_G, I will do that imedialy.
the file is attached
greetings, norus
greetings, norus
- Bea_curves.FCStd
- (738.56 KiB) Downloaded 21 times
IMHO, you should try to make InterpolationCurves (DetectAligned= true), 20 vertex each, then make a JoinCurve with all.
After that, try to use Filling feature?
- Capture.JPG (36.39 KiB) Viewed 492 times
SOLVED: curves wb, boundary to surface how to do
Thank you, it works. -selecting the linepices of the border, ->change to curves - joincurve to create a spline -> surfaces, the first (borderlines) and the surface is done -> path - offset and the solid is created.
thank´s for your help.
norus
norus
- FreeCAD_plate.PNG (69.39 KiB) Viewed 444 times
