Yes, but it's only a part of the problem. Navigation style may need to be reapplied to fetch the parameter, otherwise it may not be detected. I'll experiment with it later.openBrain wrote: ↑Fri Sep 20, 2019 2:53 pm The simplest (but maybe not optimal) method is probably to directly tamper then restore the global FC parameter with something likeCode: Select all
FreeCAD.ParamGet("User parameter:BaseApp/Preferences/View").SetBool("_PARAM_",_VALUE_)
How to simulate human vision ?
- DeepSOIC
Re: How to simulate human vision ?
My real model is an assembly. The image below is just a drastically simplified illustration of a flat dashboard and a steering wheel.
Boolean operations can't resolve the problem, what is required is clearly a projection mechanism. I know almost nothing about rendering technique and never used such a tool (I'm more into pure engineering). Does a rendering tool can fully compute projected shadows and is it possible to disable the diffusion mechanism into a scene, thus having a neat difference between illuminated areas and shadows ?
As I said I'm a total newcomer to this field, but it seems ray-tracing can do the job. I suspect our binocular vision brings some subtle differences but this is probably a very similar problem, and RT can yield an accurate approximation. Concerning the RT workbench, it would be convenient to set the light source(s) directly into the scene (using a point and a vector) with an interactive tool (something like the tool for moving a part.) And also directly edit the parameters using a panel.
