Triangular Pyramid
leoheck
Triangular Pyramid
Postby leoheck » Fri Sep 20, 2019 1:36 am
Hi folks, do you have any tutorial on how to make a pyramid? I want to make a triangular pyramid (aka tetrahedron). would like to model something like a Four-sided die
Re: Triangular Pyramid
Postby chrisb » Fri Sep 20, 2019 5:21 am
- Sketcher or Draft: create the rectangle
- Draft: create the point and place it in the right position by changing its Placement
- Part: Loft between the rectangle and the point.
kisolre
Postby kisolre » Fri Sep 20, 2019 1:12 pm
Her is a PD tetrahedron with basic dimension edge length:
PD_Tetrahedron.FCStd
(15.67 KiB) Downloaded 33 times
Postby chrisb » Fri Sep 20, 2019 3:58 pm
Here is a PD tetrahedron with basic dimension edge length:
I like this model much more than the often used lofts with an ever so tiny polygonial tip.
leoheck
Postby leoheck » Tue Oct 01, 2019 7:12 pm
@sisolre your method is elegant, I liked too.
@chrisb, I was using the one you described but it is not that clean. :)
pl7i92LCNC
Postby pl7i92LCNC » Wed Oct 02, 2019 5:33 pm
if you want to print it cris methos is a bit better to cura
if you like to stay a real solid its more to the point version
cron
