Hi, trying importing point cloud by Points WB.
By description in Wiki - Polygon cut: cuts a point cloud with a picked polygon - I thought the polygon 'select' whatever is inside the polygon.
However, there is nothing clicking the button.
Wondering what exactly this command do, the correct procedures to use it, or what else is it exactly? Also wonder how a 2d polygon 'cut' a 3d points group?
Thanks.
Points WB - - - How to use Polygon cut ?
Re: Points WB - - - How to use Polygon cut ?
Please link to the page in question in the wiki, thanks
Thanks Kunda1
Points Module Wiki is here -
https://www.freecadweb.org/wiki/Points_Module
Nothing yet in Polygon Cut.
I can confirm that it doesn't work any more as it should. Btw, in the Mesh wb you will find a similar command and there it still works.Wondering what exactly this command do, the correct procedures to use it, or what else is it exactly?
The points are projected onto the screen and thus become 2d points.Also wonder how a 2d polygon 'cut' a 3d points group?
Thanks for the explanation and hints about Mesh WB.wmayer wrote: ↑Sun Sep 22, 2019 12:36 pmI can confirm that it doesn't work any more as it should. Btw, in the Mesh wb you will find a similar command and there it still works.Wondering what exactly this command do, the correct procedures to use it, or what else is it exactly?
Whilst I am trying to figure how to use the Mesh WEB, do you mind have a look at Points WB possible bug?
- https://forum.freecadweb.org/viewtopic.php?f=3&t=39528 [Bug? Points WB] - 50x50 points import become 25x50
This fixes the cutting: git commit 8b9dfab46
Amazing, so quick!
