FreeCAD sketcher slowing down due to restrains
japie
Postby japie » Sat Sep 21, 2019 7:29 am
Hello, with attached drawing FreeCAD is slowing down to an unacceptable level, there are a lot off restrains but not that much, it looks to me that most of the trouble is caused by using == on objects and was wondering is this caused by a bug/leak or due to internal calculations?
gordelplaat.FCStd
(73.08 KiB) Downloaded 8 times
OS: macOS High Sierra (10.13)
Version: 0.19.18260 (Git)
Hash: dbf0644b60c35273525985fa13859ad39b0c10df
Python version: 3.7.3
Qt version: 5.12.1
Locale: English/Netherlands (en_NL)
kisolre
Re: FreeCAD sketcher slowing down due to restrains
Postby kisolre » Sat Sep 21, 2019 7:47 am
This should be at lears 6 sketches - one external contour, 3 for the holes that can be linear patterned, one for the longer hole and one for all other holes. There are 474 constraints in that sketch. What number would you consider too much?
Postby chrisb » Sat Sep 21, 2019 10:25 am
NormandC has stated a limit of approximately 100 constraints for FreeCAD models, and I think this is still a very good value.
Hello, with attached drawing FreeCAD (latest dev rev. on osX) ...
If you want to inform people here about your version - and it is a good idea to do so -, please attach your FreeCAD infos as described following the IMPORTANT link above. The forum is often searched for similar issues, and I am quite sure that in a month your information will be utterly wrong.
japie
Postby japie » Sat Sep 21, 2019 11:19 am
To be honest it shouldn't matter if there where 10 or 10e6 constrains ;-) And no this can't be 6 sketches (wel it can off course) since my lasercutter only except dxf files so it would be handy if I can export it as one file instead of 6 different ones ;-)
I understand your point btw but I draw from the POV from machining, so one sketch that's gonna be laser or watercutted (or lathe work if it's round) for the base material, holes or shapes that are gonna be machined afterwards I draw as separate steps so my drawing tree contains the same steps as the production steps.
There is a big difference in what constrain type uses for system resource, just connecting dots doesn't do anything but using a lot of == does, if I don't do == but set true measurement for those objects the system doesn't slow down (no matter if it are lines or arcs) so it's not the number of constrains but the used type, can't it be that == is leaking memory or triggering a constant calculation loop or something weird?
ps: modified post with build info, forgot that sorry.
DeepSOIC
Postby DeepSOIC » Sat Sep 21, 2019 11:49 am
But it does. Sketcher internally builds quite a few matrices with a size m*n, where m is number of internal DOFs and n is number of internal constraints (amounting to circa 2x the constraints you see in the list). For fully constrained sketches, m==n. Solver runs quite a formula for each element of that matrix for each iteration, that can take some time.
For 1e7 constraints, one matrix alone will take 8e14 bytes of memory, i.e. almost a petabyte.
japie
Postby japie » Sat Sep 21, 2019 12:55 pm
So every all ready solved element is recalculated at every change? And every recalculation contains all different possibilities in one formula?
Don't think my system is up to that :lol:
Thanks for responding, I am an end user and use what is convenient for me so sometimes I hit the limit? (for "the" you can fill in "FreeCAD's" or "my" as you please ;-))
DeepSOIC
Postby DeepSOIC » Sat Sep 21, 2019 12:57 pm
Yes, it has to be done to test if the element is indeed solved.
DeepSOIC
Postby DeepSOIC » Sat Sep 21, 2019 1:19 pm
Regarding dxf export. I'm not 100% but quite sure, the object to be exported as dxf doesn't have to be a sketch. It probably can be a face. Then, you can use Boolean operations on faces (in Part workbench). Relevant operations you might be interested in:
* Part Make Face From Wires (in Part WB menu), to convert sketches to faces
* Draft Array
* Part Cut, Part Common
* Part Union, don't forget to change its "Refine" property to True to merge faces.
You can also build a 3d solid in PartDesign or elsewhere, and then use its face for your export (Draft FaceBinder will help with face extraction)
DeepSOIC
Postby DeepSOIC » Sat Sep 21, 2019 1:22 pm
Also, you seem to be using complex arrangements. PartDesign Patterns can be difficult to set up. Lattice2 add-on workbench may come in handy, as it allows to make arrays on edges, which you can draw in sketcher.
sgrogan
Postby sgrogan » Sat Sep 21, 2019 2:14 pm
You can multi-select many sketches the export as .dxf to get one file.
