Hello,
I tried make a fillet on the inner corners between the solid cone and the body (marked in red). The result was a rounded outer corner, as the body is a single body. How do I relate to the solid and body as one, and make a fillet between them?
Thanks
Hi. You should first make a boolean union between the cone and the Body then you'll be able to add fillet.
Notice that it would have be better to set the code as BaseFeature of the body. Even better to model your cone with PartDesign tools.
Hi
1st place the cone and pad in the same body (click, slip the cone on the name body)
Maybe , you must centre pad (mideplan = true)
and select all corner (maxi2)
openBrain wrote: ↑Sat Sep 21, 2019 9:39 am
Thanks openBrain! That works. I don't have a clue, how to make the cone a BaseFeature or how to model a cone. I would appreciate some hints.
BTW, how can I mark a post as solved in this forum?
papyblaise wrote: ↑Sat Sep 21, 2019 9:55 am
Hi
Thanks papyblaise!
That's answer the BaseFeature question, I've asked openBrain. How do you select all corners? I use a tedious method of fishing each line with the mouse.
PelegS wrote: ↑Sat Sep 21, 2019 10:04 am
When it's done at creation time, you basically select the cone and click on "create a body". To do it afterwards, you can edit the BaseFeature property of the body.
Have a look at https://www.freecadweb.org/wiki/PartDes ... se_Feature
