[Solved] How to fillet inner corner between body and solid?
PelegS
Post by PelegS »
I tried make a fillet on the inner corners between the solid cone and the body (marked in red). The result was a rounded outer corner, as the body is a single body. How do I relate to the solid and body as one, and make a fillet between them?
Thanks
System:
OS: Manjaro Linux
Version: 0.18.16131 (Git)
Branch: makepkg
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 3.7.4
Qt version: 5.13.0
Locale: English/Israel (en_IL)
mirror-fixture.FCStd
(14.36 KiB) Downloaded 27 times
openBrain
Re: How to fillet inner corner between body and solid?
Post by openBrain »
Hi. You should first make a boolean union between the cone and the Body then you'll be able to add fillet.
Notice that it would have be better to set the code as BaseFeature of the body. Even better to model your cone with PartDesign tools. ;)
papyblaise
Post by papyblaise »
Hi
1st place the cone and pad in the same body (click, slip the cone on the name body)
Maybe , you must centre pad (mideplan = true)
and select all corner (maxi2)
filet cone.PNG (41.32 KiB) Viewed 764 times
PelegS
Post by PelegS »
openBrain wrote: Sat Sep 21, 2019 9:39 am Hi. You should first make a boolean union between the cone and the Body then you'll be able to add fillet.
Thanks openBrain! That works. I don't have a clue, how to make the cone a BaseFeature or how to model a cone. I would appreciate some hints.
BTW, how can I mark a post as solved in this forum?
PelegS
Post by PelegS »
papyblaise wrote: Sat Sep 21, 2019 9:55 am Hi
Thanks papyblaise!
That's answer the BaseFeature question, I've asked openBrain. How do you select all corners? I use a tedious method of fishing each line with the mouse.
openBrain
Post by openBrain »
PelegS wrote: Sat Sep 21, 2019 10:04 am Thanks openBrain! That works. I don't have a clue, how to make the cone a BaseFeature
When it's done at creation time, you basically select the cone and click on "create a body". To do it afterwards, you can edit the BaseFeature property of the body.
Have a look at https://www.freecadweb.org/wiki/PartDes ... se_Feature
A cone is basically a PartDesign Revolution of a triangular sketch. It also exists in the PartDesign CompPrimitiveAdditive
Edit your OP and prepend "[Solved]" to its title. ;)
PelegS
Post by PelegS »
Cool!
Thanks openBrain!
papyblaise
Re: [Solved] How to fillet inner corner between body and solid?
To select all line
clik "Seting / Style / filaire , now i can see all lines
