Ticket #4140: Crash on Select All (Ctrl+A)
DeepSOIC
Postby DeepSOIC » Sat Sep 21, 2019 4:32 pm
1. open attached file
selectall-crasher.FCStd
(11.25 KiB) Downloaded 7 times
2. click empty space in model tree (interestingly, this step is important)
3. Hit Ctrl+A
Illegal storage access...
Unhandled Base::Exception caught in GUIApplication::notify.
The error message is: Illegal storage access! Please save your work under a new file name and restart the application!
OS: Windows 10 (10.0)
Version: 0.19.18234 (Git)
Hash: 3af5d97e9b2a60823815f662aba25422c4bc45bb
Python version: 3.6.8
Qt version: 5.12.1
Locale: Russian/Russia (ru_RU)
DeepSOIC
Re: Crash on Select All (Ctrl+A)
Postby DeepSOIC » Sat Sep 21, 2019 4:54 pm
Narrowed it down a bit.
1. new doc
2. add two Part primitives
3. Union them
4. expand Union in tree
5. Ctrl+A
Instead of 5, I can also trigger the crash by box-selecting in tree view so that the selection includes "Unnamed". Or select the bottom-most entry and hit Shift+Arrow Up, and at the moment I try including Unnamed in the selection, I get that Illegal Storage Access error.
kisolre
Postby kisolre » Sat Sep 21, 2019 5:03 pm
Happens here with same version. Another thing is that if after that I close only the file (not FreeCAD) then create new file and add primitives selecting them in tree view does not actually select them. They dont appear in SelectionView and no tools become active. Selecting from 3d view shows in selection view and tools become active but does not show as selected in tree view.
Postby chrisb » Sat Sep 21, 2019 5:26 pm
Confirmed. So it is not system dependent.
OS: macOS High Sierra (10.13)
Version: 0.19.18095 (Git)
Hash: 27cb54009b57c1938f7ff97026c8b35c1688233f
Python version: 3.7.3
Qt version: 5.12.1
Locale: English/Germany (en_DE)
DeepSOIC
Postby DeepSOIC » Sat Sep 21, 2019 5:37 pm
vocx
Re: Ticket #4140: Crash on Select All (Ctrl+A)
Postby vocx » Sun Sep 22, 2019 7:16 am
1. new doc
3. Union them
5. Ctrl+A
This is the backtrace
Thread 1 "FreeCAD" received signal SIGSEGV, Segmentation fault.
0x00007ffff6cf47cf in QTreeWidgetItem::setSelected (this=0x4104000000, aselect=false)
    at /usr/include/x86_64-linux-gnu/qt5/QtWidgets/qtreewidget.h:395
395	{ if (view) view->setItemSelected(this, aselect); }
(gdb) bt
#0  0x00007ffff6cf47cf in QTreeWidgetItem::setSelected(bool) (this=0x4104000000, aselect=false)
#1  0x00007ffff6e0fa98 in Gui::TreeWidget::onItemSelectionChanged() (this=0x555556277170)
    at /opt/freecad-source-vocx/src/Gui/Tree.cpp:2701
#2  0x00007ffff6e1f504 in Gui::TreeWidget::qt_static_metacall(QObject*, QMetaObject::Call, int, void**) (_o=0x555556277170, _c=QMetaObject::InvokeMetaMethod, _id=17, _a=0x7fffffffba70) at /opt/freecad-build-vocx/src/Gui/moc_Tree.cpp:169
#3  0x00007ffff2c72645 in QMetaObject::activate(QObject*, int, int, void**) (sender=sender@entry=0x555556277170, signalOffset=<optimized out>, local_signal_index=local_signal_index@entry=9, argv=argv@entry=0x0) at kernel/qobject.cpp:3767
#4  0x00007ffff2c72d17 in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) (sender=sender@entry=0x555556277170, m=m@entry=0x7ffff40a77c0 <QTreeWidget::staticMetaObject>, local_signal_index=local_signal_index@entry=9, argv=argv@entry=0x0)
    at kernel/qobject.cpp:3629
#5  0x00007ffff3c80ec3 in QTreeWidget::itemSelectionChanged() (this=this@entry=0x555556277170) at .moc/moc_qtreewidget.cpp:445
#6  0x00007ffff3c840d0 in QTreeWidgetPrivate::_q_selectionChanged(QItemSelection const&, QItemSelection const&) (this=<optimized out>, selected=..., deselected=...) at itemviews/qtreewidget.cpp:2333
#7  0x00007ffff2c72645 in QMetaObject::activate(QObject*, int, int, void**) (sender=sender@entry=0x55555625ae80, signalOffset=<optimized out>, local_signal_index=local_signal_index@entry=0, argv=argv@entry=0x7fffffffbc10) at kernel/qobject.cpp:3767
#8  0x00007ffff2c72d17 in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) (sender=sender@entry=0x55555625ae80, m=m@entry=0x7ffff30fb9e0 <QItemSelectionModel::staticMetaObject>, local_signal_index=local_signal_index@entry=0, argv=argv@entry=0x7fffffffbc10)
#9  0x00007ffff2bef627 in QItemSelectionModel::selectionChanged(QItemSelection const&, QItemSelection const&) (this=this@entry=0x55555625ae80, _t1=..., _t2=...) at .moc/moc_qitemselectionmodel.cpp:479
#10 0x00007ffff2bf44d5 in QItemSelectionModel::emitSelectionChanged(QItemSelection const&, QItemSelection const&) (this=this@entry=0x55555625ae80, newSelection=..., oldSelection=...) at itemmodels/qitemselectionmodel.cpp:1902
---Type <return> to continue, or q <return> to quit---
#11 0x00007ffff2bf7093 in QItemSelectionModel::select(QItemSelection const&, QFlags<QItemSelectionModel::SelectionFlag>) (this=0x55555625ae80, selection=..., command=...) at itemmodels/qitemselectionmodel.cpp:1336
#12 0x00007ffff3c78fa1 in QTreeViewPrivate::select(QModelIndex const&, QModelIndex const&, QFlags<QItemSelectionModel::SelectionFlag>) (this=this@entry=0x55555624c7a0, topIndex=..., bottomIndex=..., command=..., command@entry=...) at itemviews/qtreeview.cpp:3880
#13 0x00007ffff3c79855 in QTreeView::selectAll() (this=<optimized out>) at itemviews/qtreeview.cpp:2678
#14 0x00007ffff3c0f4dd in QAbstractItemView::keyPressEvent(QKeyEvent*) (this=this@entry=0x555556277170, event=event@entry=0x7fffffffcc90)
    at itemviews/qabstractitemview.cpp:2481
#15 0x00007ffff3c7deeb in QTreeView::keyPressEvent(QKeyEvent*) (this=0x555556277170, event=0x7fffffffcc90) at itemviews/qtreeview.cpp:2026
#16 0x00007ffff6e032b3 in Gui::TreeWidget::keyPressEvent(QKeyEvent*) (this=0x555556277170, event=0x7fffffffcc90)
    at /opt/freecad-source-vocx/src/Gui/Tree.cpp:1275
#17 0x00007ffff3a00877 in QWidget::event(QEvent*) (this=this@entry=0x555556277170, event=event@entry=0x7fffffffcc90)
    at kernel/qwidget.cpp:8933
#18 0x00007ffff3aa14de in QFrame::event(QEvent*) (this=this@entry=0x555556277170, e=e@entry=0x7fffffffcc90) at widgets/qframe.cpp:550
#19 0x00007ffff3aaa623 in QAbstractScrollArea::event(QEvent*) (this=this@entry=0x555556277170, e=e@entry=0x7fffffffcc90)
    at widgets/qabstractscrollarea.cpp:1168
#20 0x00007ffff3c1487b in QAbstractItemView::event(QEvent*) (this=0x555556277170, event=0x7fffffffcc90)
    at itemviews/qabstractitemview.cpp:1680
The error seems to be in the Gui::TreeWidget::onItemSelectionChanged() function.
(gdb) bt full 3
        item = 0x55555b72e810
        it = {i = 0x7fffd800d220}
        lock = false
        selItems =
            {<QListSpecialMethods<QTreeWidgetItem*>> = {<No data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d = 0x7fffd800d200}, d = 0x7fffd800d200}}
        itDoc = {i = 0x7fffd800d230}
        itObj = {i = 0x7fffd800d220}
        _t = 0x555556277170
        method_relative = 17
        callFunction = 0x7ffff6e1f34a <Gui::TreeWidget::qt_static_metacall(QObject*, QMetaObject::Call, int, void**)>
        receiver = 0x555556277170
        receiverInSameThread = <optimized out>
        sw =
          {receiver = 0x555556277170, previousSender = 0x7fffffffbba0, currentSender = {sender = 0x555556277170, signal = 25, ref = 1}, switched = true}
        c = 0x5555561a0500
        last = 0x5555561a0500
        locker = {val = 140737271313600}
        connectionLists = {connectionLists = 0x5555561848b0}
        list = <optimized out>
        currentThreadId = 0x7ffff7f71780
        signal_index = 25
        empty_argv = {0x0}
I suspect it is something from realthunder's changes, since he's been working and re-working the selection and the tree view.
OS: Ubuntu 18.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.18272 (Git)
Build type: Debug
Hash: 88637aeb202b481a16cbd82c8767a0cc2745cfe1
Qt version: 5.9.5
